Question about True GDM-41 Refrigerator
Where is the ballast in a true commercial coke refrigerator?
    President:
  • 704 Answers
It depends on the manufacturer of the specific unit you have, but most of the flouresant light ballasts are installed on the top of the unit either on the back of the top illuminated name panel, or on the actual top of the unit. I have seen some that had the ballasts installed at the rear of the unit and even down in the lower section where the compressor is located.
You'll need to look around as each manufacturer has different specs for their particular units and without the wiring diagram, it is difficult to provide an exact answer to your question. If you remove the cover plate to the bottom section or look on the back of the unit, you might find the wiring diagram that could include a schematic and a line drawing showing the placement of all major components. With a little effort on your part, you should be able to find it.
Posted on Jul 13, 2009
What SIZE light bulb do i need to I replace in my GDM 12 coke fridge?
hi,this is how i fixed mine ,i took off the light tube and the little silvercup next to the light (capacitor) took them with me to home depot to match the numbers and sizes it took me about two minutes to find them, the capacitors come in silver and plastic housing and they come in pairs but not expensive,good luck.
Mar 05, 2014 | True GDM-12 Refrigerator Commercial
What size light bulb for a GDM 12 coke fridge
  • Safety shielded fluorescent interior lighting.
  • Cabinet lighting utilizes electronic ballast and T-8 bulbs for brighter illumination, longer bulb life and increased energy
  • Remove yours and take to THD or Lowe's. Could call first; make have to go to specialty lighting store if not available at the DIY stores.
    I have a coca cola cooler and it keeps running is that normal
    same question as is on your post I have coke machine GDM-23 or AE44OA it keeps running and gets a frost build up on tube at top
    Jul 11, 2012 | True GDM-12 Refrigerator Commercial
    Flourescant lights flickering
    is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
    Aug 25, 2009 | True GDM-12 Refrigerator Commercial
    The power to my Coke refrigerator is not coming on at all. When I plug it in, nothing happens.
    If that is a company's ref, it may have some protection gadget installed. try bypassing it, or maybe broken cord or plug
    Aug 23, 2009 | True GDM-12 Refrigerator Commercial
    I need to replace the ballast on my GDM 12 freezer and I need to know where the balast is located
    The ballast is located on the bottom inside wall where the compressor is located. Its usaually mounted, and can be easily removed and replaced. The ballast is rectangular in shape and has a few wires protruding from each end. To replace simply dismount the bad ballast and clip the wires. Match the ballast to a new one, reattach the wires using wire nuts, and remount ballast.
    Jul 24, 2009 | True GDM-12 Refrigerator Commercial
    Ballast
    You haven't supplied a model number... Makes a big difference. Generally speaking though you pull off the bottom louvered section and it will be inside of a post where the condensing unit plugs in or mounted against the sidewall.
    Jul 04, 2009 | True 72 cu. ft. / 2039 liter Commercial...
    We have a GDM-26 commerical coke machine. Only
    If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
    Jun 08, 2009 | True GDM-12 Refrigerator Commercial
    We have a Coke Cooler (True)-- not cooling, icing over
    thes are pretty well built unit, did you check th see is the evaporator fan motor is running at full speed" All that you may have to do is clean the evaporator and maybe change out the evaporator fan motor. True has a special one and you cost should be arouud 75 dollars wholesale.
    Dec 16, 2008 | Frigidaire FRS23KF7AB Side by Side...
    True GDM-41 Refrigerator Logo
    727 people viewed this question
    Top True Refrigerators Experts
    Dennis Boxerman
    John Tripp
    John Tripp
    Are you a True Refrigerator Expert? Answer questions, earn points and help others
