Question about Foxconn 661MX Motherboard
Can I connect as a slave a ATA hard drive? - Foxconn 661MX Motherboard
  • 59 Answers
Yes
Posted on Jul 13, 2009
Un maxtor diamondx plus 9 120GB ATA/133, lo quiero usar como segunda unidad y esclavo, como debo poner el jumper
to connect as a slave have HDD1 as a master and then HDD2 as a slave you can have these attached to the same ATA connection, of course there can be problems with this, if i were you i would put both to cable select takes away any hassle of getting it wrong
Jan 10, 2014 | Maxtor Hard Drive
I have placed this hdd into an external case to use as a portable drive but when i plug it in to my laptop (mac book pro) it starts to beep. Windows is installed on the portable drive i was hoping to plug...
at ATA hard drive there is no master or slave, if you want to make it master connect it at ATA slot 1 at mother board, and if you want to make slave connect it at ATA 2 at motherboard
i hope this helpfull
Jan 19, 2011 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Hi where is the jumper to put the hard drive into slave position on a hitachi TRAVELSTAR HTS541080G9SA00 ? I cannot find it Many thanks best regards
Hi
There are no jumpers to set on a SATA drive since they all use individual interfaces with the motherboard.
All you can do is connect the drive you want as master to the first SATA header,slave to the second,and then set the boot priority in BIOS.
They don't have jumper pins like the old days.
Post again if you have questions,and if this helps would you rate my post?
Bob
Aug 22, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
Someone just gave me a maxtor hard drive model 5TO20H2 how do i check to see whats on it. i may want to keep it as my master because i have no space on the hard drive im using and my windows is a pirate...
you can install it as a "slave" harddrive by connecting it on the second spot on the IDE ribon (grey looking connection , connecting to first harddrive). but before you do that, you have to change to "jumper" to match the "slave" on the back of the second hard drive. then connecting it. so where you turn the computer on, the system wil see it as a second hard drive and u can see what is in it. and use it as a storage if need to be,
Jun 15, 2009 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Hard drive spins up but windows does not see it
Depending on your PC make model and BIOS it may not auto recognize the second drive, check those settings. and or it might not support the drive size, in which case look for a BIOS update for your system. You also might want to use "cable select" on the switches even though you set it to slave it may not like that.
Apr 24, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
What 2nd "Slave" hard drive should I buy to match my "Master"?
Any size hard drive should be compatible, but you should get the same connection type and bus speen if possible (ATA/133). If you get one from a different manufacturer, you'll have to install the bios update that comes with it and set the jumper to slave per the instructions that invariably come with any "add-on" hard drive.
Dec 29, 2008 | Mobile Rack - 3.5 Inch Hot-swappable...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Installing a ata hard disk.
I dont quite get how you've got them connected so I'll tell you how I'd do it.
First of all, it is kind of standard to put the primary drive at the end of the cable but it doesnt really matter. I go with what ever physically works best.
Connect your 2 IDE devices to the same IDE channel (cable) unless you have 2 IDE channels then put each on their own channel or cable. Make sure you are using 60 conductor cables for each.
If both are on the same cable:
Set the dvd's jumper to slave.
Set the hard drive jumper to master
OR
vice versa.
*Some DVD burners do not like to be slave, or even on the same channel as another device.
The following is the ideal set up
If each is on their own channel (cable):
Set each to master
Be sure bios is set to auto detect for all channels, master & slaves.
** If this doesnt resolve your problem, please post a comment before rating.
Oct 17, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Foxconn 661MX Motherboard Logo
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
