Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLR5067W TV turns on and after an inconsistent amount of time (sometimes a few minutes, sometimes hours) the pictures goes black, audio stays on for a few seconds and the TV turns off. Anybody know the problem.
  • 2 more comments
  • STEVEGUY Dec 04, 2007
    TV SHUTS OFF AND ALL LIGHTS ON POWER BUTTON STAY LIT UP
    STAND BY/TEMP,LAMP,TIMER YOU CAN HIT POWER BUTTON AND TV WILL TURN ON AGAIN.
    THE TV SHUTS OFF AT RANDOM TIMES
  • pammyszoo Dec 27, 2008
    I have a HLR5067W DLP TV purchased in 2005 that turns itself off spontaneously. At first once or twice per day, then once per hour, so we replaced the lamp. The problem returned and has continued to escalate until now after it's been on for a while it will turn off every few minutes and won't turn on again until it rests. Also the sound cuts out intermittently when the unit is on.
  • tfb0917 Jan 02, 2009
    I also purchased my TV in 2005 and now it randomly turns off. I turn back on and it will stand on for few minutes. After about 3 to 5 times turning on and off it will remain on.This problem is now happening when I first turn TV on.
    Lamp and fan appear to be workin while on.
    Sometimes I here buzzing sound before TV turns off.
  • mookush Jan 05, 2009
    Television began turning itself off once or twice a day about a year ago. Now it has gotten worse, the television will turn itself off about 5-10 times a day. The tv will be on and then it will turn off and I will turn it back on and then it will turn itself off and I will keep turning it back on until it stays on. Sometimes five or six times until it stays on. This cycle used to only be once a day but now it is happening twice a day.
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Posted on Nov 19, 2007
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
TV is connected to cable; when we have a picture it is terrific. There are several times during the day when we have audio but screen is black. Unplugging and waiting an hour or more sometimes helps but...
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
Nov 14, 2010 | Sansui HDLCDVD325 32 in. LCD TV/DVD Combo
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My Samsung HLP4663WX has no picture, can't power off
it may be a bad DMD board. This is usually the problem when you get the three lights of death.
Sep 17, 2009 | Samsung Televison & Video
TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Jun 19, 2009 | Mitsubishi WD-52725 52". Rear Projection...
I have an older admiral tv. The picture goes in and out.
check the terminals of the yoke..it might have a loose connection..try to resolder...otherwise you need to check both horizontal and vertical output..
Jun 14, 2009 | Televison & Video
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
SAMSUNG DLP TV HLR5067W
The main board is more than likely the cause of the trouble. Time for a new TV.
Oct 29, 2017 | Samsung DLP HL-P4663W 46" Rear Projection...
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
272 people viewed this question
Jerry Greenberg
Jerry Greenberg
