Question about Maytag Dryers
Runs and heats but will not dry - Maytag Dryers
    President:
  • 704 Answers
Fist need to know if it is gas or electric dryer, it makes a difference.
If an electric dryer, It is possible that one of the heating elements has failed (burned out), which would still allow the other one to get hot, but not enough to completely dry the clothes during the normal timed or automatic drying cycles.
You can check this with an ohm/amp meter if you are comfortable with working around 220V-AC voltage, etc. You'll need to remove either the rear cover, (if your unit has rear access) or the top of the dryer and then the drum, to gain access to the electric drying elements. This depends on which model you have and how old a dryer it is, etc.
Once you've done that, you can sometimes see a broken drying element, if not, you can check for continuity with the ohm meter (make sure the power cord is unplugged!).
If you are unable to determine with this method, you can restore power and briefly put the dryer into a timed dry cycle (drum and drive belt removed, while you visually check for heating elements turning red/orange as they heat up. Only do that long enough to confirm which element is good, be very careful, as they get extremenly hot. Once you know which one is bad you can order your replacement by model number , etc. Hope that helps.
Posted on Jul 13, 2009
Duet. Why does it run but no heat and doesn't dry clothes?
You most likely have a bad heating element.
Try this video
Jun 10, 2015 | Whirlpool Dryers
Dryer runs but does not heat. It runs continually
If your dryer never quits on its own, then your main selection switch may be bad. Even if the clothes don't dry, the timer should still only run to the end of the cycle and then stop. The problem with the lack of heat could also be caused by a bad timer switch, but that is rare. Usually it is caused by a bad igniter/heat sensor unit. Sometimes you can use a piece of sandpaper and clean the carbon off of the sensor and then it will sense heat when the pilot flame starts, then it will let the gas valve send gas to the main burner. The heat sensor it the part that is in the flame of the pilot light.
Jun 11, 2010 | Roper RGX4634KQ Gas Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Dryer runs but does not get hot and dry
It runs since the motor is still working and turning the drum. No heat since the heater element is broken so no heat got produced to dry clothes. Replace the heater element to correct the problem. Good luck
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
My Dry runs, how ever it dose not heat up and dry
To be sure, you need to test the element with a meter, and also check the thermal fuses and or thermostats for continuity.
Jan 18, 2010 | GE Dryers
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
Aug 29, 2009 | Frigidaire Dishwashers
Dryer does not dry
If you are able check the plug and make sure that you have power on both legs. 220 is split into 2 legs of 110 one runs motor 1 runs heating element. If both legs have power than it is more than likely the heating element.
Apr 08, 2009 | Dryers
Does not heat up when drying clothes
heating element is most likely shot.
good luck
please mark the post with a fixya
Feb 19, 2008 | Hoover Nextra HNWL 3126 Front Load Washer...
Dryers Logo
127 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
