Press On switch, no response.
Switch out 13A fuse with working 13A fuse from kettle, no change, washer fuse works in kettle, Switched back.
Plug washer into another (working) power socket, no change
Removed lower back panel, removed black rubber assembly, removed coins, stickers, labels and bits of wood(!).
Cleaned assembly and drainage hose with white vinegar.
Reassembled, no change.
A week later I noticed that when plugged into wall, flick wall switch, red LED display flashes up briefly and disappears.
Any help greatly appreciated!
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
It depends on how long you switched on. *check to make sure that the switch is transmitting electricity if not... *from my experience with kettles you will need a new element*Depending on the kind of kettle you are using check the power cable and the base of the kettle to make that there is contact between the kettle and the power cable.
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle. Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
I'll assume that you mean a uk 3 pin plug. You can access the fuse by levering off a small plastic cover with a flathead screwdriver. Replace with another known good 13A fuse or test it (either with a continuity tester or in another appliance).
If your washer doesn't seem to work at all, check these: No powerCheck to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?Lid switchIf the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
There is no internal fuse in the washer to replace. If you have replaced the fuse, make sure that is is a good one. If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious. Trust this helps.
Probably the wires inside melted together and now as shor circuit occurs it causes the fuse to blow. remove the bottom of the kettle and check the wiring. There's no rocket science, so you'll identify the problem after visual inspection.
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
