Question about RTO Lawn Boy 6.75hp Mower
Mower won't start with key
Starting morot turns but does not engage engine
  • 3 Answers
You have one of three things going on, either your battery is is low, in which caes you shouls have it tested to ensure there is not a dead cell. or you have a bad ground, remove the starter and clean all mating surfaces with a wire brush then reinstall if this doesnt help ensure that your battery is completly charged then try using a jumper wire from the battery to the starter if the starter does engage at this point then the solenoid is bad and needs to be replaced.
Posted on Jul 14, 2009
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Troy Bilt Kohler 18hp riding mower won't start.
there is a main fuse . usually hidden in the wiring . contact a dealer for assistance
Oct 07, 2017 | Troy Garden
My 2002 Yukon Denali XL shut down while my wife was driving it on the highway.When I reached her the truck's battery was completely dead. I purchased a new battery and now there's power but the...
Define - It attempts to turn over but won't catch and run ???? When you turn the key to start does the starter engage an spin the engine ? This would be a crank no start condition . If the starter doesn't engage an spin the engine this would be a no crank no start condition . Sorry to ask but i have only been an auto tech for thirty years an have heard a lot of different discriptions for these simple actions . crank no start or no crank no start . Very different diagnostic procedures . So when you turn the key to start , does the starter engage an spin the engine ,but won't start an run ?
Jan 27, 2018 | 2005 GMC Yukon Xl Denali
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Jul 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
YARD MAN 42 '' RIDEING MOWER WON'T START PROBABLY SAFETY PROBLEM
safety switches that all riding mowers seem to have include a seat/brake safety which means that you have to be sitting in the seat or the brake must be engaged for it to start. also there is the blade engaged safety, which means the mower will not start normally with the blades engaged.
if you meet those conditions check the switches themselves
non safety related, do you hear a click or a clunk when you turn the key to the start position, this is the starting coil pulling in to send power from the battery to the engine starter, all safety switches will interupt power from the key switch to the starting coil
if you hear the coil energize and the engine does not start you have low battery voltage or loose connection or some other mechanical problem
Jul 03, 2011 | Craftsman 25cc Gas Line Trimmer
RTO Lawn Boy 6.75hp Mower Logo
176 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
