Question about Sonicwall PRO 3060 NFR (01-ssc-5378) Firewall
Open Port Sonicwall
Im using sonic wall pro200 i want to open specific port how should i do that
  • 135 Answers
1. If the port is to be opened for internal people to access the port outside the network, add a firewall allow policy in Firewall -> Access Rules -> LAN->WAN
2. If the port is to be opened for external people to access the port in the network, add a firewall allow policy in Firewall -> Access Rules -> WAN->LAN
Posted on Jul 22, 2009
How do i open a specific port on my soniwall tz210 firewall router?
Ports are communication channels for computers and networks.
Certain applications that run over or connect to the Internet require the use of certain ports.
Firewalls block the use of many ports because they can be like open doors, which viruses and hackers use to gain control of your computer.
However, if you have an application that needs to use a port that the firewall has blocked, you can go into firewall and open that port.
Following these instructions will allow you to open a port in the Windows Firewall and give you guidance for other firewalls.
Go to the control panel and click on "Windows Firewall."
If you are using another firewall application, open that application from the Programs menu.
If you are running Microsoft Firewall, you will have to work with both applications.
Verify the status of the firewall.
The first pane that comes up is the general tab and it should indicate whether the firewall is on or not. If the Firewall is not on, chose the "on" option and click "OK."
Open the Firewall application.
Go to the "Exceptions" tab and choose "Add Port."
Give the port opening a name.
Type in the port number you want to open, then choose either "TCP" or "UDP."
In most cases you will select TCP.
UDP is used for connectionless networking that doesn't require an initial connection to send information.
Or right click on the "Network Internet Access" in the bottom task bar select open network and sharing then select see full map you will see all available connections
Hope this helps
Oct 03, 2012 | SonicWALL TZ 210 (01SSC8786) Firewall
I have a sonic wall firewall and at a school site, and everytime I have inactivity on the internet, I get booted out of the internet and I am asked to re-log in with the sonic wall prompt. Is this a...
Yes. The sonicwall is set to provided authenticated Internet Access only. Once your session is up you need to log back in. You can change the timeout. Most sensible places set this to about an hour.
Aug 19, 2011 | SonicWALL 01-SSC-7436 (01SSC7436) Firewall
Problem in Sonic FireWall
Check with your ISP for whether they have blocked Port POP3 Port 25 or not. also allow (Open) this port in Sonic Firewall also.
POP3 Default Port 25 but many provider use different Ports so also make sure that you configured correct port.
Feb 26, 2010 | SonicWALL TZ 210 WLS-N TOTAL-SECURE NTWK...
I am using Sonicwall Pro 2040. I am trying to connect Sonic Wall gateway but it is asking for pre-shared key instead of user and password please help me. regards pratap
pre-shared key is a must for connectivity. only after inputting this, you would be prompted with user id & password, if configured to.
Sep 02, 2009 | SonicWALL Pro 2040 Firewall
Sonic wall 170 fequently goes on safe mode
Upgrade the firmware & see if u have all the security bundles upto date.
Jul 04, 2009 | SonicWALL TZ 170 Firewall
VPN Connection problem with DSL
contact your ISP and ask them to enable IPPAssTHROUGH on your system.
make sure the ports::
TCP 10000
UDP::500, 4500 should be open
Mar 30, 2009 | SonicWALL Global VPN Client for PC
How to switch over opt port to wan port in sonicwall
In order to do this, you will need to order the sonicwall OS enhanced. You can do this from your mysonicwall.com account.
After you upgrade the firmware, you will have a network load balancing option. you can then set the primary and secondary connections and use the active/passive failover option that is provided.
Jan 10, 2009 | SonicWALL Content Filter List (01SSC2733)
How to configure Sonicwall TZ 190? I have connected console to the Sonicwall and trying to open it via Console. But no configuration or prompt is coming. Kindly help ASAP.
open control panel and then add printers and other hardware, then up in left hand menu go to system then hardware, device managed and check if your driver is updated. if it says it's working properly then uninstall it and it'll pop back up reinstall then it should work fine.
Dec 03, 2007 | SonicWALL TZ170 (01-ssc-5740) Firewall
Sonicwall PRO 3060 NFR (01-ssc-5378) Firewall Logo
1,415 people viewed this question
Top Sonic Computers & Internet Experts
Ali Reza
Level 1 Expert
Are you a Sonic Computer and Internet Expert? Answer questions, earn points and help others
