Question about HP iPAQ H3635 Pocket PC
Ipaq unresponsive I replaced the battery on my ipaq 3635, placed it on the cradle to charge it overnight, now it doesn't work at all; I did the hard reset with no luck. Not even the charge indicator turns on. Did I do anything wrong? Am I missing something?
  • ambulance306 Nov 17, 2007
    I PUT THE OLD BATTERY BACK, AND IT'S STILL UNRESPONSIVE. I DID WHAT YOU TOLD ME TO DO; I REMOVED THE BATTERY,PLACED IT BACK ON THE CRADLE,AND NOTHING HAPPENED
  • wtavcar Oct 24, 2008
    I have roughly the same problem with my H3600. I was not using it so I put it in a drawer. I was told that these batteries should not be let drain to zero. So....I put the wall charger in the unit and left it there (~ 1 month). I went back the other day to re-start and reload all. It will not start. I press the button and all I get is a blank screen. I opened the little door on the bottom and turned it off then on. No cigar.
    Kept my old battery (thinking I may have fried the battery) and tried to swap the old battery back. Nothing. Same behavior. The screen lights up but does not boot.
    Comments?...before I ebay it as scrap
    Scholar:
  • 59 Answers
That's a very odd scenario. Have you tried putting it on the cradle without the battery? One possibility is that it was an incorrect battery that you put into it and it somehow fried the PDA. That's however very unlikely. Have you tried putting your old battery in it?
Posted on Nov 17, 2007
I have an HP rz1710 pocket pc. Can't seem to get battery fully charged. It gotten worse over time. After charging overnight or all day, it still shows low battery, then displays the hp IPAQ screen with...
If the unit will work while in the charger, it is most likely the battery has reached the end of its useful life. If this is the original battery, you are quite fortunate it has lasted this long and have taken good care of it because these batteries seldom last more than a two or three years before needing replacement.
Jan 02, 2011 | HP iPAQ RZ1710 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My HP iPAQ hx4700 Pocket PC will not start up. It
Slider switches ok and pointing at the right place in the bottom?
1. Main battery possibly needs replacing.
2. Replace backup battery..
http://www.youtube.com/watch?v=cYwc_-ISnsA
Jul 13, 2009 | HP iPAQ HX4700 Pocket PC
Compaq iPAQ 3850 Not charging/turning on
Try this - don't give up Leave it charging, even if it takes three days. I sold one a few years ago on ebay and the buyer was insistent it wouldn't charge. Eventually it did start charging and there were no more problems.
Jan 24, 2009 | Compaq iPAQ H3850 Pocket PC
Compaq Ipaq not Charging
As I understand it, the basic cradle that comes with the Compaq Ipaq 3870 does not charge. If I were you, I'd either seek out a charging cradle or google the instructions for modifying your cradle to charge. Good luck...
Dec 02, 2008 | Compaq iPAQ H3760 Pocket PC
Ipaq H3835 PDA - won't hold charge??
If you purchase a new battery, they usually come with directions and special tools to change the battery. I had the same issue with 2 of mine when I got them at a used electronics store. IF it is the battery that is not working, then replacing it is easy, and you can get a replacement at your local Battery-Plus store.
In my case, one was fixed by a new battery, the other was not, and I actually had to press pretty hard in the cradle to get the second one to work. It never worked out of the cradle, so I gave that one to a neighbor kid to tear apart and see if he could get it working. (I got them for $15, so no big loss.)
Apr 21, 2008 | HP iPAQ H3835 Pocket PC
Ipaq hw6500 wont turn on
If the battery was inserted to the unit prior to its storage, it might be the cause. Try charging battery directly in its cradle overnight or use new battery pack. If not then its hardware and/or formware problem. Sometimes electronic gadgets fail to work after prolonged storage due to to capacitor/condenser in its circuitry.
Mar 27, 2008 | HP iPAQ hw6500 Pocket PC
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
No power to Ipaq 3715
Just did this one, please refer to
http://www.fixya.com/support/t395532-not_turn
For the solution
Jul 29, 2007 | HP iPAQ RX3715 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ H3635 Pocket PC Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
