Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
How to remove the deck on the mower.
Trying to remove the deck to work on it.
    New Friend:
Model # is 2060358
Posted on Aug 22, 2016
  • Amy Niles
    Amy Niles Aug 22, 2016
    Where can I find a manual for it as well?
  • 376 Answers
What is the model number from under the seat?
Posted on Jul 13, 2009
  • Dwain Pippen Jul 13, 2009
    Sorry that was not susposed to be a solution, but a clarification question. Anyway, post that number and I can tell you what you have to do. Dwain
How o you change the lift assembly on a craftsman ZTS 7500 mower ?
Should be relatively simple. There are 4-5 cotter pins that connect the mowing deck to the bottom of the mower. Pull the pins, push the metal rods out, and remove the deck!
Jun 17, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have rusted and worn pulley on my mower deck. I have new pulleys. How do I remove the old ones to install the new ones?
How do they install on to the deck.If they are splined with a bolt holding them then remove the bolt.Sometimes the housing bolts to the frame of the deck with 3 or 4 bolts.Clean the deck and area to be worked on real good and see what kind of hardware is holding it to the deck.Hope this helps.
Nov 05, 2012 | Husqvarna Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
When trying to start fuel spits out of the carburator
Remove carb float bowl. Clean bowl. Get model no. of engine and get new float bowl gasket set at mower repair store. Ensure float drops down freely with float bowl removed. Push up on float to stop fuel flow. If not working properly replace float and meter needle.
May 31, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Do I have to remove the mower to replace the secondary drive belt?
detaching the deck is the best way to do a drive belt, the first time you do the deck can be a mind bender, but you can mark the items place with tape and a pen so it makes it easier to install and or pictures. you can bend the belt guide bars rather than trying to remove them and bend them back into place when the belt is back on
Oct 20, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a Sears Garden Tractor with a 48" mower deck. By working in long, thick grass I broke the mower belt -- not the one that transmits power from the engine, but the belt that sits in a pulley on...
I believe that tensioner pully has to be loosend up and moved.
Here are the instructions for this.
  • Place the deck in the lowest position using the hydraulic piston (if applicable) or the manual cutting-height adjuster.
  • 2
    Remove the deck-to-PTO belt from the PTO by releasing tension on the idler-arm pulley. This is a spring-loaded handle that turns in only one direction by hand and relieves the tension on the belt. Slip the deck-to-PTO belt off the PTO pulley after the tension is relieved.
  • 3
    Remove the deck from underneath the mower or tractor.
  • 4
    Locate any belt stops and loosen them with the ratchet wrench and proper socket. Belt stops are located on the deck and are the small metal brackets that guide and secure the belt to the pulleys so it will not jump off when under heavy use, or stretch from normal wear.
  • 5
    Remove any pulley covers by removing the retaining screws using the ratchet wrench and a socket.
  • 6
    Loosen the idler-pulley retaining bolt (located on the underside of the mower deck) to replace the deck-to-PTO belt. Removing the bolt is not necessary. Loosen the pulley enough to wiggle the belt free from the pulley and remove and replace the belt.
  • 7
    Remove any arbor covers (if applicable) that conceal the arbor pulleys by removing the retaining screws with the ratchet wrench and a socket to replace the mower arbor belt.
  • 8
    Locate the tensioner pulley on the mower arbor belt to replace it. Loosen the tensioner pulley bolt enough to slide it and release tension from the belt. Remove the belt from the arbor pulleys and replace it.
  • 9
    Slide the tensioner pulley back leaving about 1/2-inch of play in the belt and tighten the bolt. Reverse the procedure to put the rest of the mower deck back together and reinstall on the mower or tractor.
  • May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    I am trying to find out how to replace the mower belt of my 2006 LT2000 23hp Craftsman lawnmower
    Replacing the belt is easiest if you drop the deck. There are roughly 6 pins you must pull (refer to sticker on deck) including the engagement cable. Pull the deck from under the tractor and remove the plastic pulley shield from the left side. Remove the belt and replace the same as you took off and re-attach the deck to the mower.
    May 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    I am trying to replace my mower deck belt. I
    got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
    Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
    Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
    423 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
