Question about Zodiac Duo Clear System Chlorine Generator
Zodiac LM3 24S won't turn ON
I have had the LM3 system for almost two (2) years now. I perform regular maintenance on it to clean it. It has always run fine until about two weeks ago when it started to give me trouble turning ON.
It basically turns ON when power up, the lights come up as usual, but then after about 4 seconds it shuts OFF. I would have to turn it back ON again a couple of times with the Power Button until it would finally stay ON. The Cell would not work until it stays ON (I know because I can see the white cloud in the water at the Cell).
Last night the console decided to die. It now turns ON, and after 4 seconds it shuts OFF and I cannot turn it back ON with the Power Button. I have checked cables, power, cleaned the Cell (again), and everything seems to be OK, but the unit is not producing chlorine (the water is clear in the cell) and the console stays OFF. Only the Super-Chlorinate light comes ON and OFF if I press the Button which it doesn’t make sense anyways as the water in the Cell is always clear, so the Cell is obviously not producing Chlorine.
I will call tech support tonight when I get home, but I also would like to know if anybody here has an idea on what to do or what is wrong.
Thank you in advance.
  • dannydibuono Jul 14, 2009
    Fixed it!!!
    I found out about the Reset/Setup hidden button that the Control Panel has and I gave it a try.
    I?m not sure how many functions it can do (depending of the combinations of buttons used and an specific sequence) but I was able to do somehow a reset for the unit using it.
    It started to work back again and that is what matters now.
    If anybody has a problem with the LM3 units and read this, just look for the hidden button and give it a try before you spend $$$ on a wanna be technician. The button is located on the lower left corner right on top of the LM3 Symbol (just press with your finger and you will feel it).
    Recession is not that bad after all. It has made me look for my own solutions before I go and spend $$$. I just took away a job from somebody else, but life is tough anyways, don?t you agree?
    Thank you anyways.
  • 52 Answers
Two Things come to mind, the board, or it could be that the life of the cell has expired.
The Pool Tech
Posted on Jul 14, 2010
2 Suggested Answers
thepatioman
  • 52 Answers
SOURCE: Can't adjust the chlorine output level of Zodiac LM3-15
Nost often it just needs to be cleaned. Calcium build up can clean in a tub of 1 Part muratic acid to 5 parts warter. or a 2 to 1 soultion of vinigar and water, otherwise it could be faulty. Cleaning typically works.
The Pool Tech
J C Penney Model 6950. Why does it only run in reverse?
Bad switch. fwd/rev switch is rusted, broken or worn.
Aug 05, 2015 | Sewing Machines
Tip
Computer Care
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to Save Money with Preventive Computer Care
The most important activity that you as a computer user can do is to keep your computer as clean as possible. Your system's user guide is the best source to find specific information about how to clean your system's outer components; but here are some basic tips you should always follow.
Computers are an everyday part of life in the modern world. However, computers require special attention and care in order for them to function properly and to operate safely. Here are some basic guidelines to help you maintain your computer equipment and to keep your equipment functioning for a long time. After all, keeping your equipment running will save you money.
Prevention to be taken on your computer
  • Keep computer equipment away from direct sunlight to prevent overheating.
  • Keep computer equipment away from direct exposure to water or humidity to prevent damage.
  • Keep computer equipment in a clean and dust free area.
  • Always use surge protectors to prevent electrical surge damage to your system.
  • Place an anti-static mat in the area where you are operating your computer to eliminate or prevent anti-static damage to your system.
  • Have your system's interior cleaned at least once every year to keep it running smoothly and to protect your investment.
Things to be cautioned about while operating your computer.
  1. NEVER eat or drink while operating your computer. Food crumbs can easily damage your computer.
  2. NEVER place an open container containing water on or near your computer to avoid electrical shock.
  3. NEVER use your computer's keyboard with dirty or sticky hands.
  4. NEVER allow your pets near your computer. Dust and hairballs can accumulate inside the computer's case and cause your system to overheat.
  5. YOU SHOULD NEVER spray any type of cleaner into your computer's air vents or you could damage your system.
Computer maintenance
Basic computer maintenance should be part of your regular routine. Keeping your computer dust and dirt free, will guarantee that your computer will last and will give you years of reliable performance. Please consult your user's guide for more specific maintenance practices and intervals.
How to clean your computer system
Computer systems require cleaning of internal parts especially when used outside of a clean environment. However, only an authorized technician should open the computer case and clean sensitive electronic components. Consult your user guide to determine the best interval for internal cleaning and take your computer to a certified technician.
Monitor screen
Your computer monitor is likely to be the component that will require the most attention, because computer monitors tend to get dirty from regular use and from dust. To clean your computer monitor or LCD, you can use special chemicals design to clean computer monitors without damaging them.
To clean your computer's screen you can use OPTECH CTR Screen Care. This special cleaner is an anti-static cleaner and coating which safely removes fingerprints and smudges from computer display screens. This cleaner also leaves the surface treated with an invisible dust repellent film, which contains an optical ingredient which fills-in minute scratches eliminating surface distortion and reducing eye fatigue.
How to apply a computer screen cleaner
First, NEVER spray the cleaner directly onto your computer. Instead, spray a lint-free cloth lightly with the computer screen cleaner, and then clean your screen. Be sure to hold the cloth away from your computer when spraying the cleaner to the cloth.
Keyboard maintenance
Dirt and other debris can fall or accumulate between the keys and cause damage or prevent the keys from functioning properly. To clean your computer's keyboard you must use either canned air/gas or a small computer-specific vacuum cleaner. NEVER apply any cleaner or liquid directly to your keyboard. If the keys are dirty, use a lint-free cloth that has been sprayed with computer cleaner to lightly and carefully clean your computer's keyboard. DO NOT clean your computer while the computer is operating, and avoid using your computer till the cleaner has dissipated to avoid possible damage to your equipment. Consult your user's guide for precise instructions on your particular machine.
Case/Tower maintenance
Your computer case will require maintenance. You should remove dust and grime from your computer's air vents and your computer's case. ALWAYS use canned air/gas to clean your computer's vents or air intakes. Canned air/gas cleaners are idea for cleaning air vents, keyboards, disk drives and computer case crevices. The exterior of your computer's case can be cleaned with a lint-free cloth sprayed with an anti-static computer cleaner. When in doubt about how to clean your computer system, ALWAYS consult your user manual or call your system's technical support department.
Safe and clean computing will save you money!
Following these basic computer care guidelines should help you to take good care of your computer system, and keep it running for years. Preventive maintenance will keep your system from having problems and will save you money in the long run. For specific questions about your particular system, you should ALWAYS check your user guide or contact technical support.
on Feb 27, 2010 | Computers & Internet
Tip
Fix Slow Computers
Computers are used to make our tasks easier and perform them in shortspan of time. However, if your computer starts working slow, then thereis no major significance of having it and using it to carry out varioustasks. Many people get frustrated with the slow performance of their PCand end up spending money by upgrading memory or even sometimes bypurchasing a new computer to get rid of slow performance. However, youcannot do it every time your PC becomes slow. You should look for amore efficient solution.
There are numerous ways to fix your slow computer without having to spend money or to carry your PC anywhere.
Computers can become slow due to several reasons. Given below are some of the possible reasons:
1. Low disk space available on the hard disk
2. Presence of excess temporary files
3. Corrupt registry entries
4. Large number of software applications installed on the computer
5. Presence of incompatible device driver in the system
6. Excess heating of computer
7. Corrupt data
8. Corrupt operating system
9. Presence of virus and other malicious software
There are various other problems which may slow down your computersystem. Now, let us highlight some important steps to fix the issues ofslow computer performance with Windows operating system. Note: Take abackup of your complete data before carrying out any steps.
1. Remove all the temporary files stored in your computer system. Thetemporary files are voracious eaters of system memory. So, the bestpractice to improve the system performance is to regularly delete thetemporary files from the computer.
2. Regain the hard disk space by launching the Disk clean up utilityprovided in the Windows operating system. If even after cleaning up thehard disk from unnecessary programs and files, the space available onthe hard disk is less, then you can uninstall old programs which arenot in use.
3. Update Windows by turning on the automatic update feature when connected to Internet.
4. Registry is a central database of any computer which maintains arecord of the activities and stores them in the form of registryentries like when you install any software application on your PC thenan entry is made in the registry about the installation of thesoftware. So, check for any registry error.
5. Install a good security suite like antivirus and antispywaresoftware and scan your system for the presence of any suspiciousprogram code installed on your computer and eating up your computermemory and remove it to make your system fast.
A computer is a machine which requires regular maintenance for showingbetter performance. Regular maintenance is the best way to improve theperformance of a slow computer.
on Feb 03, 2010 | Computers & Internet
Make computer run faster
You can speed up your PC with the help of these tips given below:-
1) Defragment & Optimize files in the hard disk regularly.
2) Disable the unwanted start up programs.
3) Defragment the registry if needed.
4) Uninstall unnecessary programs (Games, crapware, toolbars, etc.)
5) Install latest Windows updates.
For task 1, 2 and 3 use reliable program like I always use "RegInOut" for the best performance. Remember that Windows need above to be optimized from time to time. So regular maintenance is required.
Dec 01, 2013 | Kaspersky Labs Computers & Internet
Acer n 214 laptop becomes no emergy
Oct 31, 2013 | Computers & Internet
Is there a manual for preventive maintenance?
every 3 months and more in the summer I spray my outside unit with a garden hose. I start at the top of the grill and work my way down. dirt and grime will come out the bottom. jeff
May 27, 2013 | Ruud UAKA048 Air Conditioner
My laptop is running slow
Simply put, if you want to fix the problems more efficiently, try the Lenovo speed up program, available here: http://www.speeduplenovo.com/
If that still won't help, upgrade hardware!
That's it!
Apr 21, 2012 | Lenovo Computers & Internet
Acer 4720z. sluggish performance
The first thing is always make sure that you dont got any trojans, viruses, worms, or spyware on your computer.
www.avast.com Offers a HOME EDITION free Virus scanner,
Download this
Install
Remove your computer from the internet, and do a FULL SYSTEM SCAN
Step 2, would be just cleaning out the files and cookies on your computer though internet explorer.
In Internet explorer click on "TOOLS"
Then "Internet Options"
under "Browsing History, under the general tab click "Delete".
Please rate me and give me feed back, ty for your time and I hope this works for you.
Sep 27, 2009 | Acer Aspire 4720 Notebook
Does not always heat
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Jul 21, 2009 | LG DLG5932W Gas Dryer
ZODIAC DUOCLEAR 25K DOESN'T FUCTIONING WELL
I have the zodiac duoclear system and have used it for nearly two years. All in all, it's a very good system. I have had similiar issues on occassion. Have you tried the master reset button on the lower right hand face of the control board? I've been able to clear up the lights by resetting the system.
If the salt content in the pool is not correct, the system will not allow you to superchlorinate. Your salt level should be at 4000 ppm. The add salt light is programmed to come on if the system gets below 3600 ppm. When the system is below 4000 ppm, it is unable to generate the chlorine needed. The lower the salt, the less you can chlorinate. Might not be your problem, but I've run into this before too.
The lights for replacing your cartridge puzzle me. I'm making an assumption that your pool is probably dirty if you're trying to superchlorinate. The dirtier the water, the faster the electrode in the cartridge will get covered in scale from the current and conversion process. Try cleaning the new cartridge by placing it in a bucket with a 75% water and 25% muratic acid mix. Let it soak for a few minutes and gently swirl it around in the mixture. This will clean the contacts in the cartridge.
Keys with the Duoclear system: Salt content and clean the filters regularly. Don't know if this will solve your problem or not, but good luck.
Dec 30, 2008 | Zodiac Duo Clear System Chlorine...
Zodiac Duo Clear System  Chlorine Generator Logo
2,533 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
