Question about HP USB Web Camera
How to connect to remote camera - HP USB Web Camera
    Guru:
  • 402 Answers
To create new Camera Window
  • Click New Camera from the File menu.
  • Camera Setting dialog box appears.
Camera Setting dialog box helps you control selected video source. To open the Camera Settings dialog box, select Camera Settings from the File menu.
Set a preview rate in the Preview Frame Rate box. It indicates the number of frames per second in the camera window. The default value is 10 frames per second. This value doesn't interfere with broadcast or record frame rate.
Remote Cameras
Remote camera is another Active WebCam program with enabled Remote Access launched on remote computer. Both programs use UDP protocol to communicate each other. If connection with Remote camera goes through firewall, make sure that the IP address of your computer, local and remote ports are opened on the firewall, and the UDP protocol is enabled.
To connect to Remote Camera
In the Device tab click to select Remote Camera.
Specify the computer address in the IP address box. Don't place the protocol prefix (like http://) in the address, just four digits of IP address delimited by dots, like: 192.168.1.101. You can find out the remote computer IP address by clicking Get Computer IP Address from the Tools menu on the remote computer.
Type port, which is opened on remote computer for remote access in the Remote Port box. This value is specified in the Port box in the Broadcasting | Remote Access properties on the remote computer.
Specify port, which will be used to receive data from remote camera, in the Local Port box. If your network uses firewall, make sure that Local Port and computer's IP address are opened in the firewall. Use the Check the Port Availability button to make sure that this port is not used by another program.
If the remote computer requires authorization, enter user name and password in the appropriate boxes. The authorization could be set in the Broadcasting tab in the Camera Settings window in the Remote Access Additional Settings window on the remote computer.
If the Remember Password check box is checked, the user name and password will be saved among the session parameters.
Cycle through cameras
If you have multiple cameras you can set up a cycler to have the program to change cameras automatically.
To configure the Camera Cycler:
  • Click Camera Settings from the File menu.
  • Select Cycle through cameras to activate cycler.
  • Type cycler interval in seconds.
Select cameras to cycle.
Posted on Aug 31, 2009
Cant find the right remote switch
I can't find a connection connector for a wired remote, and I can't find an infra red sensor, for a IR remote. Then in the menu settings nothing is mentioned about remote control settings, so I think your camera does not support any remote control. So if you want to shoot on a tripod, without touching the camera, you have to use the Self timer. See the manual page 58
Jan 21, 2014 | Canon PowerShot SX50 HS Digital Camera"
Hi there, I am having connecting my Hahnel Wireless Remote to my Nikon D90, I have not used the camera in a while and as far as I can remember, all you have to do is connect the remote to the camera. I...
To use the wireless remote, you need to set the camera's shooting mode to one of the remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode waits two seconds for you to hide the remote behind your back.
You can download a PDF copy of the manual from
http://support.nikontech.com/app/answers/detail/a_id/16087
You can order a printed copy of the manual from
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.215425500
Nov 06, 2010 | Cameras
Remote was working fine.all of a sudden it stopped working.I put new batteries but still don't work.What could be the problem?
First of all check if the remote is working. How do we check the remote? Use your phone camera. While watching the LED in the remote through your mobile camera, press any remote button. You should see the LED flashing. You can't see the LED flashing by naked eye but with the help of camera you can. If the remote LED transmit the signal (if it flashes) then the remote is working fine. In this case your TV has the problem. If you can't see the LED flash, then your remote is the problem.
Open up your remote and check if there is dry or broken connection, or short connection.
Aug 31, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
How to attach remote shutter release (RM-S1AM)to
HI,
You need the RMT-DSLR1 Remote Commander for this model. You have the wrong remote. The camera only has a USB connection for a PC or printer.
Mar 11, 2010 | Sony Alpha DSLR-A380L Digital Camera with...
Software
driver of your D53 is not compatible with PC's running Vista. camera has plug and play connection with PC and when transferring files, camera could be connected to PC without downloading driver. It will come up as DCIM or 100SSCAM folder. If you tried to connect your camera to PC but it is still not recognized, try to download remote service for camera in samsungcamerausa.com under support and remote service.
Dec 13, 2007 | Samsung Digimax D53 Digital Camera
Remote cable release
The remote cable RM-CB1 can be connected to the power battery holder HLD-3. The RM-CB1 remote cable cannot be connected to the camera body directly.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Start up delay when using the MC-EU1 Remote Control with Coolpix cameras
When you turn the camera on it senses a device plugged into the USB port and must wait to determine what is connected (computer, remote, etc.). It may take up to ten seconds for the camera to realize that it is not connected to a computer and become ready to take photos. If you turn the camera on and then press the Shutter button on the Remote it will turn on almost instantly.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon Coolpix 4500 Digital Camera
Aug 30, 2005 | Nikon Coolpix 4300 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
HP USB Web Camera Logo
1,453 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
