Question about Kenmore Sewing Machines
I have a Kenmore model 1551200 and it keeps breaking the thread at the needle
SOURCE: thread keeps breaking
347 singer Bobine setting
Posted on Dec 30, 2007
yeroc
  • 397 Answers
SOURCE: needle keeps hitting the plate and breaking
possibly off timing,
Posted on Jan 21, 2008
Zenqi
  • 208 Answers
SOURCE: the top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Posted on Jun 17, 2009
SOURCE: juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
Posted on Sep 10, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
What is normal tension settings on a kenmore model 158.12112
The tension depends on what you are sewing but usually a 4 -5. Also make sure thread and needle are the correct size for the materials you are sewing. and make sure needle and bobbin are threaded correctly and that needle is not, blunt or bent. :)
Mar 21, 2017 | Kenmore Sewing Machines
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
Kenmore model#1385 thread keeps breaking machine never been used
Install a brand new needle. A bent/dull/damaged needle can cause broken thread.
Use only good quality thread--no old thread or bargain bin variety.
Make sure you are using the correct type of needle and thread for the fabric you are sewing.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjD746LkPvNAhXEwj4KHbIQBdUQFggnMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles
Always Raise the Presser Foot then rethread the machine from the beginning. Check that the thread path is correct. Incorrect threading will also cause thread to break. (Make sure the thread is not hanging up on the thread spool causing it to break.)
Set the upper tension somewhere around the midway point (this is the standard factory setting). Test. You will probably need to tweak the tension to get it where the two threads meet in the middle of the fabric.
If the thread continues to break, there may be a burr or nick somewhere on the needle plate or the bobbin area that is catching and breaking the thread.
Jul 17, 2016 | Kenmore Sewing Machines
Kenmore serger thread keeps breaking
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Mar 26, 2013 | Sewing Machines
Thread breaking all the time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Dec 30, 2012 | Kenmore Sewing Machines
My thread keeps breaking. bobbin thread seems to be alright, have changed thread, needle.
Dec 16, 2012 | Kenmore 19606 Computerized Sewing Machine
My needle thread doesn't break, but when I go to sew, it unthreads itself.
make sure to keep long thread tail for the top & bobbin
of 4 to 6 inches & pulled behind the needle
Aug 04, 2012 | Kenmore 15516 Mechanical Sewing Machine
I have a Kenmore sewing machine model# 385.15008100 my needle keeps breaking??????
I bet you are using a cone of thread???? If so....wind thread from the cone onto a bobbin and use this as your upper thread.
Dec 20, 2010 | Kenmore Sewing Machines
Birds nests under fabric and thread breaking.
My manual says the needle thread tension is too loose , OR the needle is to fine/heavy for the thread being used.
Jan 24, 2009 | Kenmore 19001
Needle keeps breaking the top thread...
In general, there are three main causes for this...
wrong needles (Singer), low quality thread (dual duty or all purpose), incorrect threading. Be sure to thread the needle from front to back.
Sep 01, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
