Question about Sony Handycam HDR-HC3 HDV Digital Camcorder
Video breaks up
During playback my video images often break up and then will drop out altogether. There is no hint that this is happening during recording. It's completely random but seems to happen when the lighting is low. I can't tell if it's the camera or the tape. Cleaning the heads doesn't seem to help.
  • Spamfighter Nov 20, 2007
    Thanks; unfortunately, it looks like I need a repair.
  • 64 Answers
What we do at work is run a tape in ff and rw that has been recorded with completely and then use a soft head cleaning tape for twenty secs if that doesnt work then it needs to go in for repair.
Posted on Nov 19, 2007
I just changed the breaks on my 2004 optra 5 ls and there are still spungy? What could be the problem?
Most likely cause is air in the break lines. This can happen if the break lines are not bled during the break job. If you did bleed the lines during the job you may be low on break fluid. If the fluid level is OK then you should bleed the breaks again, making sure the fluid level stays high.
Jan 29, 2015 | Cars & Trucks
Hi, I have recently purchased an SR7005 which is connected to an HD PVR via Audioquest Cinammon HDMI cable. While watching programs, I lose audio immediately after an advertisement break. If I pause...
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
Jun 12, 2017 | Marantz SR7005 Receiver
Dvd movies
Maybe you had the same problem as I did... the unit may have been dropped or mishandled during shipping or maybe during installation. If it is still under warranty, return it. If not, try this:
I took mine to a technician that went through the settings, found nothing wrong, except for the fact that it won't play video. What he did afterward was open the unit up and checked out inside. Apparently there was just some little plug that got loose and/or fell off inside. This probably happened during shipping or could have happened if someone dropped the unit I guess. Anyway he re-plugged the little plug inside and it worked fine. I'm still to pick it up and test it myself but this is what I was told today so just thought I'd share it with you guys. Maybe that's what you need to get done.
Please note that if your unit is under warranty (like mine WAS), this would pretty much void it.
Apr 22, 2009 | Pioneer AVH-P4000DVD Monitor
Jvc gr-dx28ek black screen during recording
if u can see the old videos in playback mode those videos when ur camera was ok then it is
BAD CCD !
see the link for free repairs from JVC dont worry if u are out of warranty and not on list just call them PLS RATE ME FIXYA for help
http://www.jvc.co.uk/template.php?page=100102
Apr 14, 2009 | JVC GR-DX28E Mini DV Digital Camcorder
Blue lines appear across screen during video playback.
thank you for choosing Fixya.com.
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
goodluck
please don't forget to rate our answers properly.
Mar 03, 2009 | Panasonic Palmcorder PV-GS12 Mini DV...
Pauses during playback on home dvd player
Im using Verbatim discs and they work fine... try those
Jan 05, 2008 | Canon DC210 DVD Camcorder
VHS play back
I am having the same split screen black and white problem. I don't think anything simple will fix this. I have looked into the unit and almost all the video processing happens on one little PC board under the DVD. I think that the capacitors on the bottom of this board are at fault, as there have been MANY noted failures of Panasonic Professional DVC decks due to these type capacitors failing.
Oct 22, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Distorted pixelated image on right side
pixelation on the right side is an indication of misalignment of the exit roller.  don't try to align it yourself unless you're experienced in this repair.
Oct 10, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Handycam HDR-HC3 HDV Digital Camcorder Logo
129 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
