Depends on what you mean by "warmed up". If you mean engine reaches normal working temprature and works normally then cuts out , but restarts wwithin 5 minutes and then carries on working normally until it cuts out again, and then restarts withing minutes...have the throttle position sensor checked. It may be that you have a warning code on the dash?
It might be the pedal position sensor alternatively.
If your engine works ok until fully warmed up this may be the problem.
If there are any symptoms before the cut out happens can you please add the details and repost thwe query
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Year make model, rough or normal start? How many miles, etc.. thanks
OK I WARMED IT UP T O OPREATITNG TEMP THEN THEN DROVE IT ABOUT THREE MILES THEN LET IT RUN FOR FIVE MINTUES PUT IT IN DRIVE IT DIES BUT STSRTS RIGHT BACK UP
