Question about Kyocera SoHo KX1 Cellular Phone
Texting screen "locked up"
My texting seems to be "locked up." When I go to the texting screen there is a message that says: "Attention, updating messages, please check later." It started with my phone turning itself off last night (I didn't turn it off---it turned itself off) When I turned the phone back on, the problem was there. Help!!!
Dear Young, if you get this message this is probably because of poor signals because cellphone sends signal to BTS which transfers data to BSC and it reaches the MSC and this is how it decodes itself on other side.
If you are getting this message your server is unable to send the message due to network congestion. You can try again later. If that is a continous problem and you are sure there is nothing wrong with signals you can check your text settings. Your message number could be wrong. You can call your helpline.
If that has helped you please press 'fixya'
Posted on Nov 29, 2007
  • 75 Answers
SOURCE: Texting
It may not be the phone. It could be your location actually. If you have replaced the phone, and it still happens, thats what the problem is. Sometimes the service area you are in, gets a horrible signal, even though your phone says you dont. It could be that. Try going somewhere else, and see if that works. Good luck.
Posted on Jan 27, 2009
  • 464 Answers
SOURCE: kyocera phone went out and cant see screen how do i forward my me
Try to check with Kyocera's website to see if there is a software update for your phone. If not, make sure no water damage has been done to the phone or if you have dropped it this can cause it as well. Dial *228 then reset your phone (turn it off then back on) try that, if that does not work try calling your phone company to get a replacement phone at no cost because it sounds like a Manufacturer problem.
Posted on Mar 18, 2009
SOURCE: KYOCERA K9, screen will not function, lites, but no information
ok, I had my k9- it was stashed in my filthy backpack, so I washed my backpack in the washer..forgot the phone for like..30 minutes..big screw-up- i pulled my soaking and newly cleaned k9 out of the washer and was like.i am screwed..I spoke to friend the next day and this is important advice..DO NOT TRY TO TURN IT ON! But Take out the battery, Then get uncooked rice-yes rice (no joke) get a air-tight zip lock -container -fill the container with rice and put the phone inside-seal-it-up...the rice will absorb all the excess moisture..if you leave it in..24-48 joke it worked for me..but if you try to turn it on before it is will fry the phone..disconnect battery.. put in dry-uncooked rice-air seal-wait 24-48-hours..wallla a dry -functioning phone..good luck--steve-o
Posted on Aug 26, 2009
  • 10865 Answers
SOURCE: My lg neon turns itself off after texting
your phone has a virus and needs a hard reset available at the lg store where you bought it or any other store than handles lg.
Posted on Feb 24, 2010
  • 485 Answers
SOURCE: last night Jan. 30 my
Maybe your phone has configured a wrong Message Service Center Number, you could compare it with another cell phone from the same company of yours.
Posted on Feb 08, 2011
0 characters
1 Points
Cant change my messaging from dictionary to odinary text
To disable predictive texting on Motorola V360:
  1. Select the "Texting," "Text Messaging" or similar option on the menu screen.
  2. Choose the "Text Options" or "Options" selection on the "Text Messaging" screen. Choose "New Message" or "New Msg" if no "Options" selection is available, then press the button associated with the "Options" selection found on the blank message screen.
  3. Select "Entry Mode" on the screen. A list of options appear.
  4. Select a non-iTap mode, such as "Symbols" or "abc2." Press "OK." The iTap entry mode is disabled.
Jun 27, 2011 | Motorola Mobility V360 Cellular Phone
When using this phone, texting, the screen goes blank during use. The phone is also slow. The L button is not working correcly. The texting in general freezes or stops.What is the best texting phone on the...
Your Phone needs to be Updated or some sort of Virus, maybe you have downloaded/sent an File to the device which may have cost virus. Take it to your closet Phone Fixer and get it updated.
Jan 24, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Palm pixi acting strange after update
It seems that they software is not compatible with the phone so kindly downgrade it or take it to nearest store before it permanently damages your phone.
Apr 12, 2010 | Palm Pixi Cell Phone
My enV2 will not send a text message. When i hit send the screen
my wife (it was her phone) had the same problem (noted above, 5/18) we tried rebooting the phone. nothing. we tried taking the battery out and starting it up again. nothing. we even tried *228 to reprogram the phone and update it. still nothing!
so she called Verizon support, and after being transferred to tier 2 support "they reset something on their end" and it was fixed. Not sure what she did with the phone to fix it, or what they did on their end. but after she got off the phone with them it was fixed. hope this works for everyone else.
Apr 17, 2009 | Verizon Communications enV2 Cellular Phone
I have a nextel I730
If you have a texting package, it is simple * even if you don't, it is the same options, just keep in mind, it is $0.15-.20 Per Txt * Menu - Web - Send Message Or Text Message
Let me know how it goes,
Please Rate Me
Apr 03, 2008 | Nextel i730
Razr v3m text problem
Have you done any modding to the phone and is it still under warranty?
Also who is it through? Provider?
Mar 19, 2008 | Motorola Mobility RAZR V3m Cellular Phone
MOTORAZR V3m "Memory Full"
Feb 17, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Screen freezes when I type a new message
it seems like this is a firmware issue or conflict between the softwares or whatever your may have downloaded. You can repair it yourself, but be careful not to brick / kill your phone with wrong softwares.
Your local repair shop can help you too, if its under warranty bring to store to flash for free.
Jan 26, 2008 | Motorola Mobility RAZR V3
Kyocera SoHo KX1 Cellular Phone Logo
165 people viewed this question
Top Kyocera Cell Phones Experts
D. E. Hev
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
