Question about Frigidaire Dryers
Frigidaire dryer quit
I have a Frigidaire Dryer. The other day, I turned the start knob and it hummed like it was going to start but did not. The drum did not turn at all. I took the clothes out, opened the top of the dryer and tried to turn it on so I could see what was going on. The drum turned like 3X then stopped. There was a burning smell, then I heard a "pop''. Now, nothing happens when I turn the start knob. The dryer breaker was not blown when I checked it so I assume a fuse in the dryer blew? what should I do? Is this something I would be able to fix or is it something best left to a professional?
  • shippeehouse Jul 15, 2009
    So, my husband opened up the dryer. There was a lot of lint inside, especially around the motor and its coils. He cleaned it up, put it back together and it works but it doesn't sound right to me. Also, earlier today, I put some stuff in the dryer and turned it on. The drum turned a few times then stopped. I turned it on again and it started. Motor going out?
  • 121 Answers
Sounds like the motor unless something is stuck in the blower housing such as a sock
Posted on Jul 15, 2009
  • lojacksdad
    lojacksdad Jul 15, 2009
    sounds like the motor unless something is stuck in the blower housing such as a sock
When we press the button to start the dryer, we hear the buzzing but the dryer does not move.
assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Jan 09, 2011 | Frigidaire Electric Dryer
Dryer does not start when I push the on button the motor hums.
If the motor continues to hum afteer letting go of the button, then it is likely a broken drum belt. If the motor hums but stops when you let go of the button, something is preventing it from turning. This could be a seized motor or a drum that is stuck, or something caught in the fan blade.
Nov 28, 2010 | Frigidaire GLER341A Electric Dryer
Drum will not rotate
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Kenmore 83142 Electric Dryer
When I turn the start knob on my Frigidaire Gallery Model GLER341A52 the motor makes a humming noise but nothing else, when I let the knob go it stops. The drum never turns or blower doesnt start it sounds...
Wow, different person, different dryer, same problem, same day. I went and got a complete new motor assembly for $170. I hooked it up, and it is still doing the same thing. So obviously that is not the answer. What did you find?
Nov 19, 2009 | Frigidaire GLER341A Electric Dryer
When i turn the on switch i hear a humming as if it is going to start but it does not. my dryer brand is Frigidaire FEQ 332 E s
Depending on the hum you hear (if you hear the sound and it keeps humming) the belt that connects the motor and the drum is probably broken.
If the hum only happens when you turn the on switch, the motor has probably failed.
Aug 31, 2009 | Frigidaire GLEQ642A Electric Dryer
Dryer only hums when I turn the knob.
Something has seized the motor. It could be something in the blower(pen pencil, golf tee, you'd be surprised what can get in there). It could also be a seized bearing on the motor. There are electrical things that could have those symptoms but I would check the mechanical ones first. Let me know what you find.
Eric
Jun 10, 2009 | Dryers
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryer will not start
I had the same problem and this is how I fixed it ,,, i did a comfortor ,very heavy when wet .....next day i tried to do a new load ...when I turned start button all i got was a hum... I removed screws just inside door at top of lip this releases top of dryer,,,, exposing drum i rotated drum clockwise to check condition of belt ....looked good ....mine is 7 yrs old ...to soon to be motor problem ....so while turning drum i held start button on and finally motor kicked in and this solved my problem...you might be able to accomplish this without taking of panel ..though you wont be able to see belt ....by turning the drum from inside dryer while someone else turns on start button
Oct 25, 2008 | GE Profile Prodigy DPSR513GA Dryer
It won't start
Sounds like the motor start winding or motor relay is bad.. or something caught in you exhast blower. See if you can turn the drum with your hand.. if so you can try, helping it take off while having someone turn the start knob if it starts you know its the motor
Aug 19, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
95 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
