Question about Garmin Quest GPS Receiver
My garmin has frooze and I am unable to reset Garmin quest
  • 24 Answers
This could get a little dicey, especially if you are not comfortable working around electronics. First try a "Master Reset". This is done by turning the unit off, then pushing the "OK" + "Page" + "On" buttons at the same time.
If this does not fix it, then you may need to take the cover off the unit. This is where if you are not comfortable around electronic circuit boards, etc, I would suggest sending it back to Garmin. There are six small phillips head screws on the back side of the unit. With a small screwdriver, remove the screws. Be VERY careful with the screws on the right side of the unit (unit facing down with antenna hinge away from you). This hold the endcap to the antenna which is spring loaded. If you take the endcap off, you need to be careful with the spring that can pop out and easily become lost. Once the back is loose, gently pry the two halves apart. There is a small plastic plug with a red and black wire in a socket on the back of the circuit board. GENTLY use a small screwdriver or something similar and remove the plug from the socket. Leave it out for a short period of time (30-60 seconds), then plug it back in. Reassemble the GPS making certain the rubber gasket between the two sections is not crimped or kinked. Gradually tighten all of the phillips head screws in a criss-cross pattern until all are snug. Turn the GPS on as usual. If it is still locked up and the reset routine I described above does not work, it will most likely need to be repaired by the factory.
Posted on Jan 23, 2010
  • 333 Answers
With the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Posted on Sep 15, 2009
My Garmin quest 2 has look up and a cant reset it.Tell me how a chal do?
Posted on Feb 09, 2010
Cant get my quest to work with windows 7
your computer must have Garmin USB drivers installed. Go to Support at Garmin.com. Download and install, then connect your Quest.
Nov 09, 2012 | Garmin Quest GPS Receiver
How do I reset my Garmin Quest. I seem to remember pressing a sequence of buttons but cant remember the sequence
With the unit turned OFF, press "OK", "PAGE" and "ON" simultaneously. This will do a hard reset on the unit.
Dec 14, 2010 | Garmin Quest GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Garmin Quest frozen
You Could try pressing the OK button and the PAGE button, together and then hold power button until it reboots and then say yes to erase all user data
This will erase all data stored on the device,
It will need re-registering and re-updating
Here register
Here update
I hope this helps
Regards.
Mar 07, 2009 | Garmin Quest GPS Receiver
Garmin Quest 2 GPS
www.batteryship.com. Look on the screen for "GPS Devices". Click on that and it will take you to a page of pull down menus. Find the Garmin menu and just look for "Quest". Battery is about $25.
Dec 18, 2008 | Garmin Quest 2 GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Garmin Quest
Press Power, Page and OK buttons.
Missing the letter S
I called Garmin customer service and they told me to plug the unit into my computer and it would reset itself and all the letters would be restored. I did this and it worked! I realize the usb cable does not come with the Garmin nuvi 250, however you may have a cable that came with a cell phone or a digital camera. My camera cable worked great.
Feb 03, 2008 | Garmin Quest GPS Receiver
Garmin Quest
If you have forgotten your PIN number, and your security location, send the unit to Garmin and they will reset it for you. You will have to provide proof of purchase.
Oct 13, 2007 | Garmin Map Source City Navigator
Garmin Quest GPS Receiver Logo
709 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
