Question about Kenmore Kitchen Ranges
Kenmore model 278 4298813 Fast Paced beeping and reads code F-7. Have turned off circuit breaker and turned it back on, still beeps
jessee007
  • 310 Answers
SOURCE: caloric gas range problem
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jan 01, 2008
Krazytech
  • 725 Answers
SOURCE: Oven Failure Code F1
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
to fix your F1 error
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
  • 360 Answers
SOURCE: my kenmore kitchen range has
First you will need to check for proper voltage at the plug (behind the range) ensure you have 120/240 volt available.
F1 generally indicates a control board fault/failure. If you have attempted to reset the unit by unplugging it for about a min. or more and plugging it back in and the F1 error code returns, you will most likely need to replace the EOC (electronic oven control) board. Parts for your unit are available through Sears or other aftermarket parts suppliers.
Please take the time to rate this solution
Posted on Jan 29, 2009
dmftrucker
  • 1922 Answers
SOURCE: My electric range is tripping the circuit breaker
unplug the unit and see if maybe you have a problem in the breaker/supply line from the house panel, otherwise does it work fine?,there also may be a bare or shorted wire in the unit itself
Posted on Aug 23, 2009
  • 13 Answers
SOURCE: Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Posted on Aug 24, 2009
7 beeps from dash in vq stato 92 model
Do you mean 7 rapid beeps and then 2 slow beeps? Google Holden body code 72 then
Aug 31, 2012 | 1992 Holden VQ Statesman
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I have a Kenmore Ceran electric slide in range, model # 629.46799895 ...it was on, started beeping, and showing fault code F1 on the screen
Sorry to read about your problem.
Try this to determine which part is needed.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
I tried to help you.Please help ma and rate/vote this responce. Thanks and good luck
Jan 04, 2011 | Kenmore Kitchen Ranges
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My range is beeping f1 where the time should be
HI. This will be a control fault. Possible touch pad issues detected. Use the procedure below to isolate the problem.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so double check before continuing.
Jan 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore kitchen range has a glass top w/4 burners; 2 oven racks w/ 1 extra in the bottom (3) total; black top,front and top control area w/lcd display. i found it off and when i tested the circuit...
It sounds like your little Computer has lost its settings, and needs to be reprogrammed, you need your manual which came with this Range to do it yourself, or you need to call in a service technician.
It wont be too expensive,because it can be re sett pretty fast.
Jan 29, 2009 | Kenmore 92320 / 92321 / 92322 / 92324...
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Kenmore electric built-in oven control panel beeping
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Kitchen Ranges Logo
70 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
