Question about Milwaukee Tool Milwaukee 1/4 Sheet Orbital Palm Sander - 6016 - 6
I need to remove the fan on my black and decker pad sander but theres no way to clamp the armature to unscrew the fan
  • ashand Jul 14, 2009
    There are two black plastic blocks behind the fan that the sanding plate screws on to. one of these blocks broke and the sanding plate jumped out as it was only held by the two screws in the other block. I could remove the broken one ok because it was broken but I won't be able to put a new one in without either removing the fan or opening up the sander housing which I also tried to do but even after removing all the screws it won't come apart. That's when I thought it would be easier to remove the fan. I already purchased a new sander as they're fairly inexpensive but I'm just reluctant to toss this one out as the motor still runs good.
    Sergeant:
  • 384 Answers
Why would you want to remove the fan? There is a good chance that the fan is molded to the shaft and can not come off.
Posted on Jul 13, 2009
Black and decker 7404 what sheets do i get
The standard sheets for this sander will be the same width as the bottom pad and about 1-2" longer. The sheets clamps under the clips at each end. Use a screwdriver to leverage the clamp up allowing the sheet to be inserted under the clamp and then let it down to clamp the sheet in place. On many older units, these clamps get weak over time and this can cause the sheet to slip out. By folding the end of the sheet over a time or two, this will make a small section of the sheet thicker and will help the clamp to hold it in place.
There is also a link here http://www.ehow.com/how_8384633_change-decker-7404-finishing-sander.html to change the sheet which is basically the same thing.
The actual pre-cut sanding sheets will be advertised as 1/3 sheet such as this http://www.amazon.com/dp/B00448EZ32?psc=1
It can be cheaper to by full sized sheets and cut them down as needed as you will get more bang for the buck.
Feb 27, 2015 | Tools & Hardware - Others
Have a craftsman belt sander. Armature bearings are bad. One end has a threaded drive pully which needs to come off to get the assembly out of the main housing. My guess is I need to remove end bearing to...
Be careful about putting the armature in a vice. Clamping it tight enough to pull a bearing may damage it. Now, if you have access to the first bearing, get a small bearing puller of this style http://www.summitracing.com/parts/WMR-W84551?seid=srese2 This is just an example to show what type should work. If there is not room for this, then there are other pullers made that have arms that will fit within the 1/8" clearance you have.
On the pulley, if it is a nut holding it on, then a regular socket will work. As stated be careful clamping the armature so as not to damage it. I would take a block of wood, say a scrap pc of 4x4 and bore a hole through it with a hole saw that closely matches the diameter of the armature. Cut it in half long ways, removing enough material so that when you use it to clamp the armature, the two half circle wood pcs don't touch. That way, it spreads the clamping force around a little more of the diameter of the armature.
If the actual pulley is threaded, then clamp the same way and you may have to rig something. Are there holes or slots in the pulley that a spanner wench would work on? There are several universal/adjustable spanner wrenches available for that type of thing. Check to make sure there is not a set screw in the hub of the pulley that keeps it locked from turning. A photo of this would make it easier to make suggestions.
Nov 06, 2014 | Tools & Hardware - Others
How do I replace the fan assembly cannot hold armature assembly to get inner bearing out without damaging armature assembly
If you are replacing the fan assembly because the internal thread that holds the rubber/velcro pad has stripped, there might be an alternative.
I had the same problem with my PEX 12AE, which I believe is a similar sander. I found that the hole is threaded a good bit deeper than the screw, so I got a longer screw and so far it's holding ok. If/when that fails, I might try repairing the thread with an insert.
Curious to know how you managed with your sander.
Feb 09, 2012 | Bosch 3107DVS Electric Sanders & Polishers
Black & decker 7448 sander sounds & smells like motor ceased up. only makes a humming noise & feels hot.
could have had a bearing problem that caused the motor to cease up, It might be time for a new one unless you are handy, if so I suggest going to dewaltservicenet.com and downloading a breakdown for the tool and make note of how you disassemble it to find the problem, If it is the armature or field it might cost less to replace it.
Oct 23, 2011 | Black & Decker 7448 1/3 Sheet Orbital...
I am recently widowed and don't know how to get the sand paper out of and onto the sander
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Oct 08, 2010 | Black & Decker 7448 1/3 Sheet Orbital...
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
My Bosch 3107dvs random orbital sander stopped working. The screw that holds the sanding disk stripped the part that it screws into. I can't tell from the exploded parts diagram, which part I need to...
Drawing REF: http://www.ereplacementparts.com/bosch-3107dvs-0603310639-random-orbit-sander-parts-c-128_1044_1230.html
To remove the Dust Fan/Coupling Assy. I did the following: I disassembled the plastic housing, removed the Backing Pad Pos. 733 and Dampening Ring Pos. 51.
It seems the Star Washer Pos. 29 holds Bearing Pos. 30. onto the armature shaft and the Coupling Pos. 27 seems to be stuck in Bearing Pos.29. I used a 30mm long M7 hex-head bolt and 11mm ratchet turning clockwise (std RH thread) to pull the Coupling and Star Washer off. Luckily, there was enough thread left in the coupling to do this gear-pulling action with the longer bolt.
To remove the rest of the Fan Assembly I removed the 2 screws Pos. 43 holding the Brush Holder Assembly, Noted the position and removed the Spring Clip Pos. 32, then removed the Armature w/ Fan and Dust Fan/Coupling Assemblies. Firmly gripping the armature I was able to remove the Dust Fan from the armature by turning it clockwise (LH Thread).
Now that I have removed the parts and believe I will be able to reassemble them, I have ordered a new Dust Fan/Coupling Assembly.
I hope this helps someone else having a similar problem.
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
Pad on 9045B sander
Remove the bottom faom pad, which should just be held on with phillips screws. Under this you will see the eccentric weight that has a screw in the middle. Not sure if it is left hand thread or not so be carefull. It is normally thread locked aswell so be firm but fair when unscrewing it. Once it's out you should be able to lever the weight of by applying equal pressure to each side of it. It will be centered on a woodruff key so be cartefull not to lose it. Also, in between this part of the base and the main body of the machine there is a rubber skirt that is clamped to both parts. Unscrew the band clamping the skirt to the base and I think you should be able to pry it apart then.
Sep 07, 2008 | Makita Tools & Hardware - Others
How do i refill a finishing sander
Without any more detail about your particular finishing sander, I do not know whether this will help, AND I am no expert, but here goes ...
I inherited a Black and Decker 1/3 sheet sander, with no manual, from my late brother. It is not their newest model -- from the yellow plastic and the general looks and wear, I would say it is from the 1980s or 90s. The sand paper is held by a sort of spring clamp at both the front and back. There is a slot -- perhaps half an inch wide and a quarter inch tall -- in both of these spring clamps. I inserted a wide-bladed screwdriver into the slot, and pryed away from the sanding pad to open the clamp and insert the new 1/3 sheet.
Hope this helps!
Nov 17, 2007 | Black & Decker Compact Power Screwdriver
Milwaukee Tool Milwaukee 1/4 Sheet Orbital Palm Sander - 6016 - 6 Logo
103 people viewed this question
Top Milwaukee Tool Tools & Hardware - Others Experts
Bill Boyd
Robin Belk
Robin Belk
Level 1 Expert
Are you a Milwaukee Tool Tool and Hardware - Other Expert? Answer questions, earn points and help others
