Question about Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens
My house flooded and two camera lenses got wet in a camera bag. what do I do? The glas is drying out but the inside of the lense still looks wet. How do I fix this?
  • 37 Answers
Unfortunately if water got inside the lens it will leave a residue on the elements. The only safe way to fix it is to have it repaired.
They will need to take it apart and clean everything.
Sorry.
Posted on Jul 13, 2009
Canon 40d got wet
Put the camera in a bag of rice to dry it out, rice will absorb any remaining liquid, after 3-4 days remove it and see if it works, if no joy, then a new camera is in your future.
May 19, 2017 | Canon EOS 40D Digital Camera
I have this camera, and there is a theme for it that says "Underwater" is this camera able to go underwater? The lense looks as if.
No, it is not water proof camera so unable to shoot underwater without water proof casing that is another product. Camera must be packed in water proof casing to take pictures underwater.
Click Sony Support link to download optional accessories brochure rleated to DSC-T700 and check AKP-THA water proof casing for this model.
Thanks.
Nov 05, 2010 | Sony Cyber-shot DSC-T700 Digital Camera
I dropped my camera in water, the lense got moisture in it but was working right away. I had opened the inside of the camera to make sure nothing got wet. I set it out to dry. The lense is dry of moisture...
Get a new camera - you will have other problem besides the obvious ones. Liquid will produce corrosive material after it drys and remain in the camera and will be difficult to remove later.
Nov 04, 2010 | Fuji FinePix F20 Digital Camera
Lense not receeding and rattle from inside
You could have blown it by now but still worth trying.
There may still be some moisture in the camera shorting out parts of the circuit. Take the battery out and put the camera in the airing cupboard, or somewhere equally warm and dry for a few days. Then put the battery back in and give it a go.
Don't be impatient, if there's still moisture in there it will take some time to dry out.
Mar 14, 2010 | Samsung BL103 Digital Camera
Is it bad to keep the lenses attached to your film cameras when storing them for 7 to 8 years in the camera bags thanks Also my Minolta maxxum 500si's view finder is not bright outside in the bright...
it's just okay to store with the lens on the camera, but it's better to have a camera body cap and front and back lens covers on the lenses with cases stored in a dry place with batteries removed from camera.
for the finder i would suggest a soft rubber eye piece accessory that fits on the finder.
Sep 13, 2009 | Minolta Maxxum 500si 35mm SLR Camera
I have a Minolta Rokkor-x 200mm telephoto lens with fungus
Lens fungus is really common and it's not cost effective to repair. Even if the fungus is removed then the multicoatings are permanently damaged.
The good news is that until the fungus becomes pretty severe the image quality doesn't suffer much as most photos use the lens stopped down to some extent and this means that if the centre of the lens is clear then there's nothing to block the light paths.
Unfortunately it does tend to spread, so keep affected lenses in a separate camera bag to the rest and if you can afford to do so then throw them away and replace your camera bag as it will be loaded with microscopic spores waiting to attack more lenses. Making sure that your camera and lenses are completely dry and free of condensation before storing them until next used will prevent reoccurence.
Jun 16, 2009 | Cameras
Fungus in the lens
These lenses arn't designed to be taken apart.
A camera specialist may help but they should alwys be kept dry and at room temp never warm and humid. Silicate gel in your storage bag also prevents this from happening.
Good luck
Marc
Apr 16, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Dropped my camera bag & my 17-55mm Lens Now will not telephoto
The best way to get it done right after you drop the lense is send it to NIKON NY . They put the lense on a resolution bench test and it make sure the resolution is great ,. This lense is very criticial and it is a must or your wasting your money . The reason is this ., The lense is a wide angle and sometimes photographers have probelms with 17-55mm lenses and sub mirror problems . So its best to be safe than sorry .
Mar 07, 2009 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
Got MY CAMERA WET
This is probably because water got on back of lense and the particles are blown up in size. You may have to take apart and clean lense on the inside. It could be dryed sudds.
Sep 10, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
I got my camera wet!!!
basically a bubble blower has a thick concentrated solution of soap. if any amount of this solution happens to enter even the lense assembly and you have given enough time to dry it up , it must be creating a friction in the movement of the lense assy. this will not allow the camera to switch on and will make noise.
Jun 24, 2006 | Sony Cyber-shot DSC-N1 Digital Camera
Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens Logo
266 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
