Question about Westinghouse SK-19H210S Television
Tv will not turn on. power cord is good.
  • Kenneth Klare
    Kenneth Klare May 11, 2010
    See solutions in "Can't remove cover to check power supply."-Ken
I have a Westinghouse Mod. SK-19H210s that is 16 months old. It would not turn on. Upon investigationg the problem I discovered bad capacitors on the power board. (2200uf and 1000uf). I replaced the components and the TV works great, you can purchase a new power board.
Posted on Jul 13, 2009
  • angela school Sep 04, 2013
    Did the TV (where the AC was plugged in the DC input) make a chirping sound, but just wouldn't turn on? I'm having same issue.
Will not turn on, no blinking lights, power coming from cord is good
Sounds like the power supply board is dead. Probably has a blown power line fuse on the board. A power surge will sometimes blow the fuse and protect the board from damage. Replacing the fuse will restore the TV if this is the case. Most times though, the supply has a blown part that causes the fuse to blow and your only option then is to replace the board.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
Tv turns off and on over and over
Hello, This may seem kinda silly but please check that the power cord is fully seated into the tv's power socket. Just remove the power cord from the TV, and re-insert it back in. Also verify that the other end is fully seated into the wall outlet or extension cord!
Good Luck
Rich Lilja
Dec 20, 2013 | Sony KDL55NX810 55 inch 1080p 120Hz 3D...
Where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
Sep 01, 2012 | Philips 32PFL3505D 32 in LCD TV
TV wont turn on. I unplug the power cord and here a clicking noise inside the back of the TV. Plug it back in and try turning it on but still nothing. I try the power button on the TV as well as trying...
Very good TV. Since this is LCD there's not much that goes wrong with them except their internal power source. You will have to get it serviced. It is not something you can do without the expertise.
Jan 23, 2011 | Dell W2600 26 in. LCD Television
TV DOES NOT TURN ON STANDBY RED LIGHT STAYS ON
Hi Friend,
Check your TV's remote battries. If they are good, then, power off the TV at the main wall socket and unplug the power cord, leave it for 5 minutes. Now, connect back the main power cord, hold the Power On/Standby button on your TV and power then turn ON main switch on the wall. This should resolve your issue.
Thanks,
Shiva
Dec 19, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
TV randomly turns itself off and on
This issue is related to the TV's main board not seeing constant A/C power to unit so the board is turning off the TV.
When the TV's main board see A/C power back to the unit, the TV will try to turn back on.
This issue could be a loose power connection for the TV or a failing part inside the TV. Do other electrical devices work when plugged into the same wall outlet?
Try the following:
1. Remove the cord from the back of the TV and reinstall it (perhaps it's loose going into the TV and was not installed correctly).
2. Try putting the cord into a different wall outlet (perhaps it's not a good outlet).
3. Try using a new power cord for the TV. (Any matching cord will work for testing)
If the above did not resolve the issue, then it could be the switch mode power supply and or the main board inside the TV. Both items are easy to change out.
I can look up the LG part number for you.
Feb 16, 2010 | LG 22LG30 22 in. LCD HDTV
ILO-2600 tv need power cord
If you use a standard power cord for most radio's all I had to do was round of the edge and turn it into a figure 8 , works good or the plug fron norelco or remington razors work too
Apr 09, 2009 | iLO 2600 Television
Panasonic pt-53wX42, power wont stay on. Turn on, no picture then it will turn off by itself after 5 seconds. The red power button will flash on and off until I unplug unit and start the whole process...
I'm no expert, but I'd start by taking a "VERY GOOD LOOK" w/magnifing glass if possible , @ UR Wall Outlet Power Cord. Change to different wall outlet. Ur Power Cord "should" just pull right out of the back of your TV. If nothing in those places, then take off back panel (or part where power cord plugs into TV & AGAIN inspect area around where power cord attached for, yeah, that's right, the dreaded black area around plug-in area. Maybe it's just a bent prong. Any other funny things going on that U didn't mention here? Good Luck Leonard aka quikstudy@cox.net
Jul 23, 2008 | Televison & Video
Televison & Video Logo
588 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
