Question about Refrigerators
The coils keep freezing up. - Refrigerators
  • 4,070 Answers
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Jul 13, 2009
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
HI HAVE GOT A SWAN SH3010 DEHUMIDIFIER BUT THE COIL KEEPS FREEZING OVER WHAT AM I DOING WRONG?
Nothing.That's how it works. The coil gets cold. The moisture(water) in the air freezes to the coil. The coil then gets warm and the ice melts, dripping into the bucket or out the drain hose.
Jan 04, 2015 | Dehumidifiers
Drain line on rheem raka037jaj cenyral air unit not draining and cois freeze up
Hello, coils will freeze either to low airflow or low refrigeramt charge. Make sure filter, blower wheel and evaporator coil are clean. If they appear clean there is a low refrigerant charge.
Jun 06, 2012 | Heating & Cooling
If i set the temp to low on my window air conditioner can it cause the unit to freeze up
Under some conditions, it could freeze up. High humidity levels can cause the coils to freeze. Not cleaning the air intake filter regularly, can also cause the coils to freeze. However, most window units can not be set below 65 degrees. But, in high humidity, it could freeze at that temp.
If you want to avoid the possibility of the coils freezing, operate a ceiling fan or other small fan as fast as comfortable. This keeps the cool air moving a generates a wind chill that fools your body into thinking it's cooler than it really is. Doing this will keep you from having to turn the AC way down and thus, save on energy cost.
I hope this has helped you and thanks for choosing FixYa.
Sep 08, 2011 | Heating & Cooling
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
My lines are freezing and the ac works sometimes and sometimes it doesnt. How do I avoid the lines from freezing
you need to check your filter to start with if thats good make sure all you vents are open and your returns are free from abstruction
Aug 25, 2010 | Honeywell Heating & Cooling
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Coils freezing up on a/c unit
hi thanks for the question i would check the air filter this is a must it has to be kept clean the only other reason is if your trying to keep the room too cold the unit.has to shut down to let that ice melt so if your trying to keep the room too cold it will never shut down don't try to get 68 degrees
Sep 27, 2008 | Heating & Cooling
ADMIRAL SIDE BY SIDE COILS FREEZING UP
sounds like a defrost problem. most of the time it's the heaters behind the coils.
Aug 11, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
