Question about Gigabyte GA-K8VM800M Motherboard
Pc No sound after format
Hi everybody i have a dell dimension 5150 due to several problems i formatted my pc but since i formatted my pc there is no sound anymore i tried to download the drivers from dell website but when i download it if i click the application ile it say windows cannot open thi file chose with what program you want to open it please help me
  • 1 more comment
  • gersom Jul 13, 2009
    what do you mean whitout extension
    now it works but when i click in the file it says
    cannot open application the application is missing required files
    it says that in the errors sumary
    ERROR SUMMARY
    Below is a summary of the errors, details of these errors are listed later in the log.
    * Activation of G:\Downloads\DellDriverDownloadManager.application resulted in exception. Following failure messages were detected:
    + Could not find a part of the path 'G:\Downloads\Application%20Files\DellDriverDownloadManager_1_0_0_0\DellDriverDownloadManager.exe.manifest'.
  • 59 Answers
How did u save it ? Usually dell provide drivers in EXE format and they are autmatically extracted. I think u saved without extension. You should rename the file and named exactly like that sounddriver.exe and try to open it. If still not working try to open the file with WINRAR, download it from www.rarlab.com
Posted on Jul 13, 2009
I had a failed hard drive replaced in my Dimension 5150. The system backup is on a memory stick. It starts to format the new drive, but then stops and gives no message. Any suggestions?
Not sure exactly what you have on the back drive or its configuration and capability, but before you can use a new drive, it needs to be partitioned, then formatted probably with the NTFS system before you can copy any files to the drive.
Hopefully, you have the original system CDs or DVDs. You can change the boot sequence to boot from the CD/DVD and proceed from there. To do this, while the PC is early in the process of booting, press the F2 key to enter the setup program. Don't forget to change the boot sequence back when the overall process is complete.
Aug 27, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No sound the sigmatel audio was removed how do i reinstall ?
Windows should see the audio hardware at boot and ask for/install drivers. If not, you'll want to download and install the latest drivers from Dell - http://support.dell.com/support/downloads/format.aspx?c=us&l=en&s=gen&deviceid=8907&libid=3&releaseid=R114282&vercnt=2&formatcnt=0&SystemID=DIMENSION%205150/E510&servicetag=&os=WW1&osl=en&catid=-1&dateid=-1&typeid=-1&formatid=-1&impid=-1&checkFormat=true
Jun 29, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
J'ai formaté le disque dur de mon dell dimension 5150. Par erreur j'ai formaté la partition contenant tous mes documents et photos de famille et sur laquelle j'ai installé windows xp. Svp...
salut ;
il est possible de recuperer vos données;il y a plusieurs logiciels de recuperation il suffit de monter votre disque sur un autre pc et lancer le logiciel . il peut prendre beaucoup de temps si les documents sont volumineux et si votre memoire est faible
bonne chance
Oct 18, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ethernet controller driver needed
You can download and install the required drivers from Dell's official website. Click on the link below:
Drivers & Downloads for Dimension 5150
On this page there are four files, download them all and install them. You should be able to use your network card after successful installation.
Note: If the above link is not working, go to www.dell.com. On the top right corner of the Dell's website click on 'Support'. A new page will open from where you choose Drivers and Download option. Next step is to choose your laptop model.
Oct 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have virus and the computer won't start. What do I need to do ?
Hi..
If your computer attacked by viruses and didn't work at all, you need to reformat your computer, after you've already done in formatting you need to install all their driver. so that sound and display well ok.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
After formating, the computer could not find a internet driver.
If you go to Dell.com and put in your service tag you can get the exact driver you need for the modem (or any other device). If you are using a different computer, copy this driver to a floppy, USB drive, or CD and use that to install the missing driver.
Apr 06, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ethernet driver
Note the Service Tag of the the PC and access the Dell website from another PC. Go into the support section of Dell website, select Download Drivers, and enter the service tag of your PC.
You should be able to find the ethernet driver for it (if there are 2 or more download both and save to a CD or USB memory stick.
Now go to your Dell. You should be able to run the program from the USB stick and it will restore the Ethernet connection.
Do the same for other drivers you need, sound, graphics, etc.
Jan 06, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Gigabyte GA-K8VM800M Motherboard Logo
431 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
