Question about IBM ThinkPad T40 2373 Notebook
Windows XP Log In screen removal
I have a notebook runing WinXP. My old employer required me to log into the network/server, so the machine was set up to log in to a domain. I no longer work there but still have the machine, and when I boot the machine the domain log in screen comes up and asks for the network password. Is there a way to eliminate this log-in screen and change the machine to a normal (no passowrd) WinXP boot without doing an OS re-install?
  • Ann_Begood Nov 16, 2007
    I also have a couple of laptops from old employers that were given to me. How can I sign in without using their log on (which I don't know what it is). Is there a way to refresh it and log on without going thru their environment?
  • zahav Nov 16, 2007
    I was able to remove the machine from the network domain, but after I rebooted, the log in screen still comes up (after I pressed cntrl-alt-del) and asks for a log in. When I typed in the password I was using, it says password is not valid. So now I can not get into the machine!
  • 98 Answers
Try removing the machine from the domain first. Right click on my computer, go to Properties, go to the Computer Name tab, and where it says " To rename thic computer or join domain, click Change", click on the Change button.
In the following screen, select Workgroup, give it any name and click OK.
Before you do this, make sure you have an account with admin privileges on the local machine (make sure you know username and password for this account).
Posted on Nov 16, 2007
Zebra 330i prints in pink or black on test print. New ribbon fitted.Cleaned and calibrated.
Either your print-driver settings don't match the ribbon installed, or you have a bad ribbon sensor. Check your driver settings via the Windows printer center screen (Win7: Start Button => Devices and Printers; WinXP: Start Button => Printers and Faxes); locate your Zebra printer, then right-click on it and select "Printing Preferences". Locate the tab for the ribbon setting, and ensure the setting here matches the ribbon you have loaded. NOTE - you must have Windows administrator rights for your Windows log-in ID to make any changes to the driver settings. Contact your network administrator if you do not have these elevated privileges, and they can log in and make any required change for you.
Aug 05, 2015 | Zebra P330i Thermal Card Printer
Log on the program
Check to make sure that your main harddrive is working. Sounds as if it is unable to find a bootable drive to configure. It would be better to get the Professional version of XP but since MS is dropping support for XP in 2013 you might have issues. I had an old Windows NT server CD that stopped working after they dropped suport on it. Not sure how that worked since it did not require internet connection to run the setup. They must of put a time code algorthym in the source code to deactivate the CD after a certain date.
Jan 10, 2013 | Microsoft Xp Home Edition Dell Version...
Two toshiba laptops, one less than a year old running win7...the other 3 yrs old runnign xp. both worked fine connecting wireless to my router sat. sun the win7 machine said the dns server was not...
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Feb 21, 2011 | Toshiba (PA3212U) Wireless Adapter
I use on my PC (Acer/Compac) My Pictures/Adobe Photoshop for the pictures I have. I have gone into the Properties section to add more information on each individual pictures. I than burned the photos...
  • When you go to the Connect to Server dialog, you may browse the names of computers that are on your local subnet.
  • You can connect to a server via its IP address or DNS name. If it is required or more convenient in your environment, you may also use other valid URL formats, such as:
    smb://ServerName/ShareName smb://DOMAIN;User@ServerName/ShareName
  • The name of the "share" (the shared disk, volume, or directory) must be specified. You will not be prompted for it.
  • You cannot type spaces as part of the share name when connecting. In place of any space in the share name, type: %20 .
  • When troubleshooting a connection issue, you can ping the IP address of the Windows PC using the Mac OS X Network Utility application (in the Utilities folder). A successful ping verifies a TCP/IP connection between the two computers. This is an important first troubleshooting step when there's no response or a timeout for a connection attempt, since SMB connections involving a Mac require TCP/IP. However, a successful ping does not mean the SMB service is also working or available.
  • Check Microsoft support resources for information about setting up file sharing on your Microsoft Windows-based computer. These may include Help files installed on your PC or the Microsoft online Knowledge Base. For example, see this article for Windows XP information: How to use the Simple File Sharing feature to share files in Windows XP.
  • When troubleshooting an SMB connection issue, use Console, which is located in the Utilities folder. These Console logs may help advanced users identify an issue: private/var/log/samba, private/var/log/kernel.log, system.log . Note that some log files only appear when logged into Mac OS X with an administrator acccount.
  • If you are connecting to Windows XP, make sure that the Internet Connection Firewall settings are not interfering with your connection. SMB uses ports 137, 138, 139, and 445. These ports should be open on the Windows XP computer. This may require "Advanced" configuration of the XP firewall.
  • If you are connecting to a Windows SMB resource, check to see if the firewall is blocking TCP ports 137, 138, 139 and 445. After trying the above steps, you may perform advanced troubleshooting by inspecting log entries in the Event Log of the Windows SMB resource (if you have access to it), and/or the Mac OS X computer's relevant logs in the Console application. If those steps do not help identify the issue, or you do not want to perform advanced troubleshooting, than you should contact your network administrator. It may be necessary to contact your network administrator in some situations in order to grant access to your Mac from the SMB resource, or its host network configuration.
  • Mac OS X uses SMB only over the TCP/IP protocol, not the NetBEUI protocol.
Dec 29, 2010 | Compaq Computers & Internet
I have just upgrade my ADSL1 connection to ADSL 2 using a Thompson tg585v7 router, the vista machine works ok, however the 2 windows XP machines have connections intermittent performance to the Internet...
You've put a networking problem in as a WinXP issue without describing the network topology.  Perhaps the WinXP systems are set up to use the original connection, and the new router eventually tires of that behavior and cuts those systems off; you can look in the router's logs around the time the WinXP systems drop off for clues.  Look things up, read the manuals, and you will have a better network for your understanding of its operation.
Nov 14, 2009 | Microsoft Windows XP Professional
Unable to send emails, but can receive emails
I solved this by changing the Outgoing Mail Server settings. Open Mail client, select Tools>Account>Properties then select the Server tab. Check Server Requires Authentication and under settings click Log on using and enter your user name and password in the boxes provided, the boxes were already filled out but you may have to enter your information.
Hope This Helps
Mar 29, 2009 | Acer Aspire 3690-2196 Notebook
Update 4090 xcdt
Yes, you can upgrade from Win98 to WinXP. The minimum hard drive requirements for WinXP is 1.5GB and the minimum RAM requirement is 64MB. You will also need a CD ROM for the install. Now those are the minimum requirements so don't expect it to go very fast. If possible I would recommend you upgrade to Win2000. WinXP and Win2000 are almost identical. The minimum hard drive for Win2000 is 650MB and for RAM it is 64MB. So you could still use your 4GB hard drive and have plenty of room. You will need a CD ROM for the Win2000 also.
Good luck if you have anymore questons let me know,
Don't forget to rate this solution before you log off.
Jan 19, 2009 | Toshiba Satellite 4090XDVD Notebook
Logging on to server
You need to go into administrative tools and look for group policy.
In the local computer policy
Computer Configuration
Windows Settings > security settings > Local policies > user rights assignment. In the right hand pane find the policy for "Allow log on locally" Set the user accounts for those users which are allowed to log on interactively on the server. Be careful you dont lock the administrator account out.
Use in conjunction with the "Deny logon locally policy" if you need to.
Hope this helps
Mar 22, 2008 | Microsoft Windows Server Standard 2003 for...
Toshiba PA1390U-1NKP fails under Windows Terminal Services from XP to Svr 2003 R2
I don?t have the equipment to test your setup; however, I suspect your problem is in redirecting the device to the terminal server session. Check the terminal server system event log file to see if you are generating any messages when you connect. When my users have issues, typically with printers, they will be listed in the log as *Errors* and the source will be *TermServDevices*. If you?re using the latest Remote Desktop Client there is a tab in options called Local Resources which is used to deal with configuring your workstation sounds, keyboard, printer, and other local resources to redirect to the terminal server. Click on the More button at the bottom and you will be taken to the more generic section of resource redirection that deals with other items. Your device is probably USB so if it is going to work is would fall under the scope of the section labeled *Supported Plug and Play devices*. You would start by placing a check in that box, reconnect and see if you keypad works now or if anything shows up in the event log. Let us know how this turns out and if you have any other questions. As always please don?t forget to rate this post.
Apr 03, 2007 | Toshiba PA1390U1NKP Keypad
IBM ThinkPad T40 2373 Notebook Logo
110 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
