What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Get a small bottle of mix oil that is metered for one gallon of fuel. Mix the oil with a FRESH gallon of premium fuel in a gas can. Shake. Fill tank of machine. Start and run machine. All done.
SOURCE: Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
SOURCE: Fuel mixture on Homelite Chainsaw
Old 330 should be 25 to 1 (200ml to 5lt ulp)
some newer OPE oils like stihl 2st are 50 to 1 ,but use around 150ml to 5lt on old saws
SOURCE: chainsaw gas mixture ratio
An XL from that time frame recommends 32:1 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d4b1071a456ca76c88256cd6001cc24c?OpenDocument
If my saw it would be adjusted for and operate on 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: want to fine gas and oil mixture ratio for
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
