Question about Konica Minolta bizhub 180 All-In-One Printer
  • 167 Answers
You MUST use the bypass tray and bve sure to enter the custom size, media type and weight in the driver. The settings MUST be set the same on the 180 before printing.
Running envelopes is a tricky situation, but once mastered it should work. Note that not all envelopes will run, try different sizes and brands and keep the ones that work.
Posted on Jan 09, 2008
How do i print a # 10 business envelope with the bizhub c200
First recommended that you use the bypass tray on the right side, also before placing the envelope in the bypass tray send the print job over first, the screen will say replenish paper then go ahead and place the envelope on the tray. and let it take it or hit the start button Ensure you select #10 commercial media and bypass tray in your print driver preferences. May also want to have tech come out and look at the tray and run MAX and Min. Adjustments.
Oct 09, 2012 | Minolta bizhub 200 All-In-One Printer
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
How to insert envelope in the bizhub C280. Where is the feeder for envelope
To insert envelope for printing use manual by pass tray.Manual by pass tray is at the lower left side of machine.Insert envelope there and start printing.Also check the pressure lever in fixing unit.Make sure it is set on envelope printing setting.
Aug 03, 2011 | Konica Minolta Bizhub C300 All-In-One...
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
Envelope printing
Microsoft Office Word will help him with that, AND keep a record of his projects. Just pick Tools/ letters and mailings/ envelopes and lables.
May 23, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Printing envelopes on the bizhub 252
After spending way too long messing around with this on my bizhub 250 here's what finally allowed me to print:
I simply changed the bypass tray setting from "envelope" to "normal". I kept the custom size the same (9 1/2 X 4 1/8) and it started to print.
Doesn't make sense, but you can give it try.
Dec 27, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 200 printing custome envelopes
Do not know if this helps, but I could not print Com 10 envelops until I said the type was "normal" - Type "envelope" would tell me I had the wrong size.
Dec 12, 2007 | Minolta bizhub 200 All-In-One Printer
Konica Minolta bizhub 180 All-In-One Printer Logo
429 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
