Question about Thomson 24WK25U 24" TV
Power button won't stay locked when pushed on. If held in with a screwdriver then the tv will power up ok. Could it be the spring on the switch?
  • 431 Answers
  • Hi I am Vortash yes it sounds as if the switch has broken and it is a common fault with many sets , one simple way of fixing it is to hard wire across the switch and turn the set on from the outlet socket .. ( be careful that you dont cross connect the switch if you hardwire it , as this would result in a direct short and blow your fuses in your home as well as being unsafe ) another solution if the original component is not available is to use another switch an attatch it to the back of the set for opperation .
What usually happens is the plastic clips that lock into the retaining slots in the switch break off giving it nothing to hold on with .. I have also used superglue on the switch as a temporary repair until a new switch can be obtained that works quite well .. but my advice is to use the manufactures original if you can obtain it .. and of course any attempted repair should be with the wall socket detatached sounds obvious I know but you would be surprised ?. hope this helps regards Vortash
Posted on Jul 13, 2009
  • 813 Answers
The spring is okay if the switch is coming back to the normal (Off) position by itself. It seems that the lock which hods the spring in position is broken or has worn out. In most of the cases the lock is not repairable and you will need to change the switch itself.
Vax zoom not staying on
It is likely that the button (switch) is defective and will have to be replaced
Jun 28, 2013 | VAX Appliances Vacuums
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
The power button on my tv won't stay on for less than a second
Open the remote control for to clean the keypads from oxide, dust, dirty with contacts cleaner.
2) retight the springs contacts cleaner for better contacts.
3) clean the contacts cleaner very well.
If this doesnot resolve the problem go to repair shop TV for fix it.
God bless you
Sep 06, 2012 | Philips Televison & Video
The power button is gone so there is no way to turn it on. is there anyway i can turn it on with the button?
You could try using a small screwdriver pushing straight in thru the hole where the power button was. If that doesn't work, put screwdriver in hole then push down on it. The switch inside the TV could be just inside the hole or up to an inch or so inside. To prevent electric short, wrap tape around screwdriver.
If that doesn't work, unplug the TV and take the back off, slide the circuit board out far enough to see how the power switch works then go from there. The actual switch is soldered to the circuit board. The power button is only a piece of plastic that actuates the switch.
Dec 03, 2010 | RCA Televison & Video
How to replace on/off power switch on TEAC CT-M343 TV
the switches have a small spring that helps click the button to stay on or off its common for the spring to snap if you have another switch just pull it appart and replace as you undo it of not you can jam the switch on with a slide of paper or match stick then turn on off at wall or put a lighting switch in line with the power cord such as from a lamp
Apr 21, 2010 | Televison & Video
Passenger power window will not go up from drivers side
Hi, what you need to do is replace the switch on the drivers side this is a common problem and replacing this switch will solve your problem.
The switch should just pop out if you use a screwdriver as they are just pushed in but buying the new one will give you some idea of exactly how they are held in.
Let me know how you get on or if you need further assistance ok
Oct 10, 2009 | 2004 Dodge Ram 1500
Brand New...Can't get it to stay on?
Make sure you have it connected to a power source properly. Push and release the power switch. (it is spring loaded) Don't push it to the lock position for now.
Jun 07, 2009 | Garmin nuvi 260W GPS Receiver
Bosch SHU43 / Siemens Dishwasher door not locking
I replaced the top cover, that required removing the door screws to get access to the front of the door to remove the 4 top cover retaining screws. After replacing all this, the door latch was in teh locked position not allowing the door to close. How do you physically re-set the lock, I tried to push it with no luck!
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
RCS 14F512T 14" TV
possibly one of the switches behind the front buttons is shorted;
could one of the front buttons be pushed in and not releasing-maybe the power button?
Apr 29, 2008 | RCA 14F512T 14" TV
Thomson 24WK25U 24" TV Logo
222 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
