Question about Dell OptiPlex GX270 PC Desktop
Dell Optiplex GX270 will not start and power button is orange
When i turn on my computer i hear the fans and HD but there is nothing on the monitor and the power button is solid orange.
I think that it is most likely that this is a power supply going bad. These can be purchased cheaply on eBay (make sure the picture matches). This replacement is moderately technical.
The other good possibility is a bad capacitor(s) on the motherboard. This is very common for the GX270s due to a manufacturer defect. Most of them failed in years 2-4, though. This would require a replacement motherboard (very technical). Pictures of bad capacitors: http://brianmorristech.com/?p=105
It could also be related to the power connector from the power supply to the motherboard (unlikely).
Another good option would be to buy a used GX270 from eBay and put your hard drive into it.
Posted on Aug 12, 2009
    Problem Solver:
  • 5 Answers
LOOK FOR CMOS SETTINGS OR JUST RESET JUMPERS , IF NOT THAN CHECK IF YOUR COMPUTER MEMORY SOCKET.
Posted on Jul 13, 2009
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
When you press power button, computer does not boot up. only orange light blinking on and off.
Possible bad power supply. Unplug and let sit for 2 minutes. If you push the button again, and nothing happens; then replace the power supply.
Jan 06, 2011 | Dell OptiPlex GX620 PC Desktop
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
My power butten is orage an if pressbthe moniter key it says power save mode on press any key or move the mouse. When I do nothing happens. I have a wireless mouse and the little recesepter thing that...
From my experience orange power button usually means 2 possible issues. One is motherboard especially if it is model gx270 or power supply issue. Unless you really know what you are doing it will kinda be hard to determine. You can open the case and look on the motherboard to see is there any capacitors that look cracked or bloated(not perfectly round) which would indicate motherboard issue. I would take it to a pc repair shop if it is worth it and have the test it. Good luck.
Nov 02, 2010 | Dell Computers & Internet
Optiplex light blinks, fan goes for a second but won't turn on
you may want to do a search on the dell website, i had that problem and never fixed it, you might find the information under service manuals search.
good luck.
Aug 11, 2009 | Dell Optiplex GX270
Fan makes a lound noise and power button is orange
It sounds as if your power supply is cooked because the cooling fan has been running slow
Only way you can check is to take a panel off and hook a voltmeter into the 12v & 5V supplies on the Hard Drive and the Floppy Drive.
Jun 25, 2009 | Dell OptiPlex GX280 PC Desktop
Computer does not start. Replaced motherboard and RAM. Hear the fan when I start the computer
The monitor has the problem. the message only means, the connector is not properly connected on motherboared . please try another monitor.
I am sure about this...monitor or the connector ( as u have changed the motherboard) of the monitor has the problem.
Apr 19, 2009 | Dell OptiPlex SX270 PC Desktop
System couldnot respond after booting dell gx270
Try to check connections between the monitor and the System Unit or what they called CPU. Turn on the computer you must hear 1 beep means the computer start normally. if you haven't, try taking out any new installed hardware but not the video card if you don't have onboard video device and turn on your computer again.. if problem still exist keep in touch.. TY
HOPE I CAN HELP
Dec 04, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Dell gx270 power switch
I don't think you need a new switch. The power "switch" on the front of computers today is a momentary action push button switch. Not a locking or clicking switch as older computers used to have.
Many of today's computers, including the gx270 / gx280 computers from Dell are really always on. You can see the green or yellow LEDs on the motherboards glow when they are "off" (like a sleep mode).
They are in a "sleep" mode until you push the power switch, which sends a momentary signal off to the motherboard to fully power up and turn itself "on".
I think you have something else happening here. When the system tries to power itself up, and detects a severe problem, it will try to automatically turn itself off.
The problem could be a bad motherboard, power supply, memory or processor. It could even be a failed hard disk that is drawing too much power (shorting out) from the supply.
If you had done something to the system, like move it or open it up for an upgrade, etc.. Look again at all the internal connections, and make sure there is nothing rattling around inside that might also be causing a short.
You could try removing all the PCI cards in the system, removing the power and data cable connections from all the disks (Floppy, Hard Disk, CD/DVD) and see if the bare motherboard (with CPU and memory) will boot by it self. If it does boot, then the problem was somewhere in those items and you can replace them one at a time until you find the problem, or if it all works again then it may have been a loose or bad connection.
If you have another machine available, you could try switching the power supplies and seeing if that is the problem.
-Chip
Nov 21, 2008 | Dell OptiPlex GX270 PC Desktop
Orange light on Dell GX270 power button
A solid orange light, usually indicates an internal power problem but just in case try reseating the memory. Also its become a habit on a GX270 to check the capacitors to make sure they aren't bulging.
Jul 07, 2008 | Dell OptiPlex 170L PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
865 people viewed this question
Alun Cox
