Question about Sony RM-LJ304 LCD Remote Control
Batteries leaked, cleaned as best I could, but doesn't work! removed two screws to access inner panel, but it wouldn't open. (I hoped to clean further}. with fresh batteries, I've tried to turn on my amp, but no go. the display on the remote doesn't function either.
    President:
  • 2,777 Answers
If you have had a battery leak then this is a very bad thing. It's possible that the battery acid could have corrupted the system board in the remote. I would call Sony to see if they have any suggestions for you, however I think you may end up needing to replace the remote.
Posted on Jul 13, 2009
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    Please if possible come back to the question here and rate it 4 thumbs. It looks like the answer helped you, but for some reason it doesn't rate it 4 thumbs unless you come back a second time and specify 4 out of 4 thumbs. I hope you will do this for me. Thanks Tim
How do you clean the dirt/food "in between" the glass in the bottom oven door
Open the oven door. In the inside you will see a number of screws along the edge of the door. Unscrew them and you will find that you can lift/split the inner panel from the outer panel. If it sticks look for more screws at the side of the door to make sure that all the screws are removed. Lift the inner panel carefully an you will have access to the "inside" of the glass panel. Re assemble by reversing the procedure.
Mar 31, 2015 | Ovens
How to remove the door panel on 1991 mercure cougar. I need to replace window motors.
DOOR TRIM PANEL
1989-92 Models
(see Figure 8 - click over pic for zoom)
  1. Remove window regulator switch housing.
  2. Remove the door inside handle cup (snaps out).
Fig. 8: Door trim panel-1989-92 models
  1. Remove the self tapping screw retaining door trim panel upper front extension assembly, and remove assembly.
  2. Remove the two self tapping screws retaining door trim panel to the door inner panel.
  3. Lift the door trim panel upward and snap out trim panel.
  4. Disconnect the wire harness for courtesy lamp.
To install:
  1. Attach the wiring harness to the courtesy lamp.
  2. Place the door panel into position, then tighten the panel to the inner panel.
  3. Attach the upper front extension assembly.
  4. Snap the door handle cup on the door assembly.
  5. Install the window regulator switch housing.
Electric Window Motor
REMOVAL & INSTALLATION
  1. Remove the trim panel and watershield.
  2. Remove the speakers.
  3. Disconnect the negative battery cable.
  4. Disconnect the motor wires and the connector.
  5. Using the dimples located on the inner door panel, drill 3 / 4 in. (19mm) holes for access to the motor.
WARNING When drilling the holes, the glass must be in the up position. The hole saw pilot must not extend more than1/4in. (6mm) beyond the hole saw.
CAUTION Secure the regulator in a vise and drill a5/16in. (8mm) hole through the regulator sector gear and the plate. Install a1/4in. (6mm) bolt and nut in the hole to prevent the sector gear from moving when the motor and drive assembly is removed.
  1. Working through the holes, remove the 3 motor and drive-to-regulator attaching bolts. Remove the motor and drive from the door.
To install:
  1. Clean the chips of metal from the surrounding area. Then coat the bare metal to avoid rust.
  2. When installing the motor and drive to the regulator and install the 3 screws just snugly enough to hold it. Remove the regulator restraining bolt and nut if the old regulator was re-used.
  3. Connect the negative battery cable.
  4. Connect the wires and cycle the glass through its run to ensure gear engagement. Then, tighten the attaching screws to 50-85 inch lbs. (6-10 Nm).
  5. Install the speakers and door trim panel with watershield.
Hope helps (remember rated this).
Jun 25, 2010 | 1991 Mercury Cougar
NEED TO REMOVE INNER SCREEN.
take the lower panel speaker covers off first, then tanke the 4 screws out below the screen, then take the bottom skeleton cover off around the speakers then you can take the 4 screws out of the bottom of the screen then the whole screen slides up with 4 tabs in all 4 corners becarefull not to pull out the plastic holders will break you need to make sure to slide it upwardes then you have full access to the inside to clean. hope this works for you
Dec 29, 2009 | Toshiba TZ50V51 50" Rear Projection...
My clean light is flashing during the cleaning and then the dishwasher stops
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
I have often found this to be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. You will need to refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 28, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
Clean light blinks 7 times dishwasher wont turn on
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
Jul 23, 2009 | Dishwashers
How to Clean the inner part of the glass for scanning
Generally you should not have to clean the underside of the glass unless you are in a high dust environment. This would require disassembly of most of the printer itself. The glass is held in by double-sided tape or a bead of glue, so don't try to remove the glass sheet itself.
The easy part is the beginning, removing the scanner cover. Next you will have to locate screws around the outside and start taking panels off. Keep note of the panels and the screws. After the side panels are off, there should be a set of screws around the scanner itself that hold the scanner and plastic casing with the scanner glass. Once those are removed, the scanner glass with its frame should be able to be removed. From there you can use whatever you would like for glass cleaning, make sure it is streak free.
Older scanners make this easier. Most of them are 4-6 screws and the top half pops off and can be easily cleaned. A multifunction isn't so fun in this sense.
Hope this helps!
Oct 18, 2008 | Canon Pixma MP800 All-In-One InkJet...
INNER SCREEN NEEDS CLEANING
Here is a picture that shows you how to remove the front screen to get access to the mirror as well.
Aug 15, 2008 | Toshiba 51H84 51" Rear Projection...
How do I remove the inner glass sheet from my oven to clean it
Remove the oven door first. There are usually 2 release tabs to flip up at the door hinges. Lift off and set on a flat surface. Then remove screws to separate the inner and outer door panels. Remove more screws and brackets until you access the glass you want to get to.
Jun 21, 2008 | Kitchen Ranges
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
GE XL1800 Door
OK, I'm no handy man and I just figured out how to do this. Open the door and remove the black plastic cover surrounding the inside glass. I used a regular flat head screw driver to pop this out.
Now I removed the 3 screws holding the inner panel against the glass on the front door. After removing the screws, the inner panel is held in place by a series of plastic clips. Go around the perimeter and pop the plastic clips out so the inner panel including the mesh comes out of the door.
Now you have complete access to clean the inside of the glass door!
I found it easier to do this operation with the door completely off the microwave, but you should be able to do this with the door in place too.
Aug 27, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Televison & Video Logo
228 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
