Question about Honda Garden
Honda GX100 gas engine will not idle, it just dies. Runs OK at WOT
    Sergeant:
  • 384 Answers
You will need to adjust the low speed idle screw. Make sure the spark plug is clean before adjusting.
Posted on Jul 13, 2009
Engine dies when when apply gas to it
Check for vacume leak including intake. Spray some carb cleaner around intake and vacume hoses and listen for engine rpm to change.
Aug 24, 2017 | Honda Cars & Trucks
Outboard seems to flood out at idle/low rpms
Check plugs had the same problem with 25hpJjohnson changed to hotter NGK plug and started using 89 obtain gas problem solved this is a ethanol gas problem
Jul 17, 2016 | Light Outboard Motor Boat Bass Fishing...
How do I fix My Honda hrx217 surges at idle runs ok at load.h
The carburetor has two circuits, a main power circuit and an idle circuit. When the idle circuit gets partially clogged, the governor will drop the throttle shut, the engine partially dies and the governor yanks the throttle back open till the main kicks in. If the idle circuit gets completely clogged, the engine will need the choke partially on to make up for the missing air fuel mixture, will run rich and surge horribly. The carburetor needs to be cleaned out, a can of Berryman's spray can dissolve the crud out and restore operation. 90% of this problem is caused by old contaminated gas
Jul 14, 2016 | Honda HRX217VKA Lawnmower
Starts right up but once it warms up it dies have messed with the air gas screws that's fine don't know what the problem is
My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
Dec 21, 2015 | Cars & Trucks
I have a1994 vf750 honda magma rode all day fine on way home bike died jump it off idle fine hit gas it dies leave cables hooked up hit gas runs great what will cause this battery really hot
battery is more than likely has a dead cell in it by leaving cables on the engine can feed off that if the engine will idle without the cables it most likely the battery replace battery and that should take care of your problem
May 19, 2014 | Motorcycles
I have a 1980 Honda 750k. I recently purchased it and it wouldnt hold an idle at all. would just die if you wasnt giving it gas. I had the carbs tore down checked and rebuilt but I am still having the same...
you may have a vaccume leak try spraying some carb cleaner around the carbs and intake ports while running and see if that changes the idle speed or allows it to idle for a second, otherwise it still sounds like a carb problem please rate
Aug 01, 2011 | Honda CB 750 Motorcycles
1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
Feb 21, 2010 | Raymarine Linear Feedback Unit For...
Idle speed engine dies when throttled
It does sound like its getting to much fuel, or the lack of air. Air filter ok? If it is you might need to have a compression check done to see how the piston rings are.
Jul 03, 2009 | 2001 Honda XR 250 R
Fuel system
Check the fuel system, chenge fuel filter. clean the fuel tank.
Oct 16, 2008 | 1994 Toyota T100
Garden Logo
488 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
