Question about Compaq Presario R3000 Notebook
Hi there, im having a problem with my compaq laptop, its not turning on. the power pack (extention cord) is functional as it works in a friends laptop but it isnt working in mine can you suggest something?
  • 358 Answers
Try to remove your battery from the back of the laptop, then power the laptop back with your power cable without the battery inside, then if it comes up, swap your battery with your friend's own (battery) also, and see if it works now.
If it works with your friend's battery inside, then you might just have to get a new battery.
Posted on Jul 13, 2009
    President:
  • 2,777 Answers
If the power adapter is not charging your laptop but it chargers a friends, then that means the DC input jack inside your laptop has either broken off, gotten pushed in, or has otherwise been disconnected. Unfortunately you will need to have the machine serviced. Your best bet would be to call Compaq support.
HI had same problem was told to depress power button for 5 secs or so
Compaq laptop, pink and green pixalted screen.
compaq day, endless posts... endless dead old PC's
who owns this old junk and why?
no LT stated, of the 1000s
no OS stated , XP?" what?
ever heard of photos, take a picture post it so folks can see reality?
all PCs break all do and often and LT vastly more often, its portable and that breaks them faster. x10.
what PC< we cant guess PC hear
LT ran at HP from 1984 to now. vast types, and compaq to.
simple tests.
1: ;runs ok with battery out , BINGO !!!! battery number 1 failure.
2: lent, lent packs vents overheats and CPu and GPU go NUTS.
all puters do this if not cleaned 1 time per year, all do. its called servicing the PC .
3: bad power pack of power is weak the electronics goes NUTS.
4: does the external VGA jack work to a external screen. yes/no.?
5: is this a 2008 Laptop with the GPU SOLDER BALL FAILURES?
next time post the PCs real model number.
or the service tag here is one random.
tag1-yurc2tkkgu0y15feq43cohvv-3-0_0.jpg this LT?
LOL 1984?
if I had any compaq relics' (most have a value of $20 or less)
id buy this.
see walmart see those great deals on pC that are good and supported?
be best,
http://pcdied.com/cheaper.html
Mar 19, 2017 | Compaq Computers & Internet
Hi, I have a Compaq Presario CQ56 & the scroll area on my mouse pad isn't working. Can this area be turned off and if so, is there a way to turn it back on/unlock it?
The scroll pad on the touch pad needs a particular driver Synaptics Pointing Device Driver. This will actually run at the startup after installed which will activate the functionality of scroll on the touch pad. You can also actually turn this function on and off so this is a friendly user.
If you do not have that driver that comes with your laptop you can go here:
http://www.compaq.com/cpq-country/cpq_support.html
or here
http://www.synaptics.com/support/drivers
Good day.
Jun 19, 2011 | Compaq Presario CQ56-115DX Laptop
My Compaq Presario 500 laptop will not turn on. I know the battery was weak. I had the computer on one evening. The next morning, it was off. I tried booting up and nothing. No lights or anything. I...
I'm thinking the same as you, the power cord is the problem, try to find a friend with the same brand of computer to try, for exemple HP have on a lot of laptop the same power cord.
Mar 28, 2011 | Compaq Computers & Internet
Intermittant power when using the power cord.
yup probably the power cord. try replacing a new one if you have or try borrow from your friend just to test if the problem is really in the power cord
Dec 07, 2009 | Compaq Presario R3000 Notebook
Laptop not powering
try a simple power cycle. Take out the battery, leave power adapter plugged in. Hold down the power button for about one minute. Then hit the power button normally this should correct the problem
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Computer will not turn on
You need to check the power cord, borrow, beg or steal one to test. If the laptop does not charge with a different power cord then the problem is elsewhere eg. a faulty power pack or even a faulty connector that plugs into the laptop (borrow a multi-meter to check the voltage of your power pack), also borrow a power pack to test your laptop, before you buy or send it away for a quote/repair.
If you determine that the laptop is faulty, then the cost of replacing a motherboard would not be worth it, even if you found one, it would most likely be a second hand one and how would you know it works, also if you are not technically minded you will it difficult to swap motherboards and it may not work when you put it together.
I suggest you put your money towards a new laptop, it will be faster and better.
Nov 15, 2008 | HP Compaq Presario R4000 Notebook
Laptop
Try removing the battery pack and then power up with the cord. If it works, then it means that the battery pack needs replacing/recharging.
If it still dos not work, the cable could be faulty. Get it replaced.
May 15, 2008 | HP Compaq Presario C304NR Notebook
Battery problem or fan?
If the laptop posts (power on self test)
and you see stuff on the screen, no matter how short , do the following: (this checks for a software problem)when booting up press F8 and when you get to the menu, boot up into safe mode,
then restore the pc back to a date before you had the problem, and/or remove any program you installed prior to you having the problem,
if that don't work Try a bootable anti virus disc, use it to check for any viruses ,
if not try a recovery disc, or operating system disc ,
both disc's will try to access the hard drive. if they do not work, (nothing has changed) nothing comes on the screen.
laptop does not post:
(then it is a hardware problem)
try the following first.check battery is seated correctly and that the power pack is functioning,
if the battery has gone flat and the power pack is not working ,the laptop will not start.
Remove any hardware you may have installed prior to you having the problem.
remove the screw(s) holding the cover plate on the back of the laptop where the ram lives and remove the memory sticks,
clean the gold edges both sides, with rubbing alcohol or a pencil eraser, and re-insert them, (not an ink eraser as it will do damage)
swap them around if you have more than one,
try one at a time.
if you only have one, borrow one from a friend or try the ram in your friends laptop ,if that's possible, or
get a friend or family member to download a "memory chip diagnostic's" program such as memcheck 1.70 and boot up of it ,it will check your ram ,if not
take the ram to your local pc shop and ask them to check it for you (they may do that for you)
if you can establish that the ram and power pack is ok, and anti virus and recovery /system disc's do not work,
it may be that the motherboard or the cpu is failing
Generally a dead hard drive would not stop the laptop from posting.
good luck with that and let me know how you get on
Terry
Mar 31, 2008 | Compaq Evo N610C Notebook
Startup/charge issue
hi.. unfortunately i've seen many cases like this and it looks as if from what you are describing that your laptop is fried if there is no boot up at all.. how old is you laptop and what brand is it?
Feb 19, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario R3000 Notebook Logo
202 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
