Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Blowing fuses I have a Husqvarna 42 " cut Lawn tractor with a 15hp Kawasaki motor....a YTH1542XP....it has started blowing the 20amp fuse after its running awile and when you go to engage the blade with the hydrostatic transmission............any advice would be greatly appreciated howard from Watson, La.
  • 21 Answers
Try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Posted on Jul 27, 2009
Battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
May 06, 2012 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
While mowing my lawn the Husqvarna YTH1542xp with a twin Kawasaki engine suddenly stopped. Will not start again, had blown 20 amp fuse, replaced fuse and starter engages, but engine won't turn over....
Maybe it threw a rod or piston.. maybe the piston seized up. Can you get the blade to rotate at all? Use a stick to try that, not your shoe.
Dec 03, 2017 | Husqvarna Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Husqvarna Lawn Mower YTH1542XP. when it is in gear to move, i have to use my foot to hold the pedal back for it to go. if i don't hold the pedal back, it barely moves. any suggestions are...
It sounds like the transmission drive belt is slipping. When you pull the pedal back you are increasing the tension on the belt. You may also want to make sure the spring that pulls tension on the idler pulley is in tact. Hope this gets you in the right direction.
Feb 23, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
My husqvarna tractor won't start. It has a new battery but no clicking or anything when I turn the key. If I hook up a portable battery charger and try to start it, I hear a grinding noise but the engine...
have you checked the fuse? there is a 20amp yellow fuse under the hood just below the solenoid same side as the blade engagement switch.also be sure all your lock out switches are working or by passed.
Feb 06, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 19.5hp 42 in deck lawn tractor blows 20amp fuse when blades are engaged replaced fuse happened again
Inspect the wiring safety switch that is at the bottom of the lever.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,436 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
