Question about Lite On (SOHC5236V) CD-RW/DVD-ROM Combo Drive
I can read CDs but not DVDs
I already tried putting in a handful of CDs and DVDs to find out if it's an isolated incident, but the results are the same. I still can't read them DVDs.
  • 45 Answers
Re: I can read CDs but not DVDs
Man if you have warranty papers try for a replacement
these are due to manufacturing damages which can be corrected only by them or experts
Posted on Dec 29, 2007
0 characters
3 Points
Hi,My dvd writer can no-longer read/burn cds and dvds.It usually fails at around 17% and ejects! costs me alot of cds that are wasted..PLIZ HELP.THANK YOU..
Open the draw and give it a blast with compressed air from an aerosol can or play a CD lens cleaning disk, if that doesn't work, don't try too hard, get a second hand replacement from ebay or any second hand shop you have near you.
Mar 12, 2011 | LG GSA-H55N DVD-RAM Burner
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Nov 01, 2010 | Sony CD & DVD Burners
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Can operate with CD ROM's. Won't recognize DVD's.
Sounds like the drive could be going bad. The way the laser reads DVDs vs. CDs is different, that is why you are able to read one, not the other. I had this happen to me, except the opposite. It could read DVDs, not CDs. Had to buy a new one, and all is well.
Apr 22, 2009 | Pacific Digital Mach 16x8x16x Double-Layer...
My DVD/CD-ROM can not read dvds
DVD/CD-RW combo drives are capable of reading the DVD's but cannot burn so try playing a DVD with some content on it also Download VLCPLAYER
if you don't have a DVD player already on your system. As far as CDs are concerned it can both read and write to CDs
Feb 01, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
My pioneer dvd rw dvr 109 does not read dvds or cds
have you tried inserting any types of cds or dvds? let me know the result.
Nov 13, 2008 | Pioneer DVR-107D DVD±RW Burner
Drive plays CDs but not DVDs
I am assuming it is a DVD drive ...
1.) Try the drive on another computer to see if it is working.. If not the drive is damaged.. Replace it..
2.) If it is working the the problem is your computer software.. BACK UP and format the drive then reinstall your windows , drivers and software, verify the drive works :)
3.) Try the drive on a different port on your main board,, If still nothing please let me know
Nov 16, 2007 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Lite On (SOHC5236V) CD-RW/DVD-ROM Combo Drive Logo
139 people viewed this question
Top Lite On CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Are you a Lite On CD and DVD Burner Expert? Answer questions, earn points and help others
