Brown spots on clothes from my maytag neptune
Every few loads of clothes I will have brown spots on one piece of clothing that I cannot get out. It almost looks live a brown grease. I have a front load neptune maytag.
  • 92 Answers
This sounds very much like that the bearings have badly worn-out,pain to replace them ?
Posted on Jul 15, 2009
I am getting little brown spots on my white clothing. Bleach seems to take them out. It just started happening.
sounds like a rear drum shaft seal may be leaking and getting either rust or brown grease spots on your clothes.If this the case,you should be able to see signs of water leakagein the back of the unit.Take the rear cover off and look in the area behind the large drum pulley.This problem also usually results in noisy operation eventually.The water would be getting into the tub bearing behind the seal.
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer is leaving dirty spots on clothes
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune is not getting clothes clean
SPOT COULD BE DETERGENT OR SOFTNER IF YOU USE IT- TRY DISOLVING DETERGENT IN WARM WATER BEFORE ADDING IT TO THE MACHINE- THIS WILL TELL YOU IF IT IS THE FAULT.
INSUFFIENT WATER WILL ALSO CAUSE THIS PROBLEM. SO WILL OVERLOADING
Jul 08, 2009 | Washing Machines
Clothes still wet on Maytag Neptune Front load - only light load
any front loader should be operated with more than on piece of clothing in it. otherwise it is unable to balance the load.
Mar 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Black, tar-like spots on some clothes after wash
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Dec 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Rust in washer
hi. thanks for the question .. well i would call this its final breath . the bearings are going. that's the rust y pieces .its time to go thanks the appliance doc
Sep 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Detergent goes where?
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Grease spots on clothes
Your drum support bracket grease shaft seal (which will require a new Lip Seal Kit #12002022) is dead and potentialy the two shaft bearing are at risk. Parts cost retail approx. $100 or so. Labor, Lookout...
I'm fighting this issue for the second time.......
Bill B.
May 20, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Clothes still wet washing on Maytag neptune
Your pump, or the hose between the pump and drum, might be clogged.  Could be spare change from unemptied pockets.
Oct 17, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
414 people viewed this question
Top Washing Machines Experts
