Question about Toro Lawn Mower With Toro Power Tools
MTD Yard Machines starter cable replacement
I have reinstalled my new starter cable. I get no tension or spring from the housing that you thread the cable into and I can't get the mower to start. I have taken the housing off 4 times and rewound the new starter cable but each time it acts like there is no tension. The cable may be too long but I hate to cut it and be wrong. This is my first lawn mower repair and I am at my whits end. I know it must be something simple but I have not instructions to help me with trouble shooting.
  • Lori McKibbin Jul 15, 2009
    Sorry, but the advise you gave me did not work. It appears the spring inside the housing is broken or has failed someway. Guess I buy more parts. Thanks for your help.
  • 376 Answers
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope through from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Posted on Jul 13, 2009
HOW CAN I REPLACE THE PULL CORD?
remove the three or 4 bolts holding the starter on the motor wind the spring loaded starter backward until you feel real good tension stick a screwdriver through the starter to keep it from unwinding thread the rope through the opening in the starter tie a knot in the end of the rope release the spring that should fix it.
Oct 20, 2015 | Yard Machines Cultivator 21A-121R900
How do i replace pull cord on mtd 31cc tiller
Remove your recoil housing. Turn the inside to see if spring is broken. If spring is good wind it up as tight as it will go without forcing it. Once you have it wound all the way then back it off one turn or until the eyelet meets where the rope comes out. tie a knot in one end and feed through both holes. Pull the rope through till the knot is tight then attatch your handle. Once the handle is in place slowly let the rope wind itself in. pull a few times to make sure your knot is holding and reinstall on engine
Jul 16, 2014 | Yard Machines Mtd Yard & Garden Cultivator...
How do i repair pull string on my yard machine 135202 tiller
remove starter
get new rope
wind spring DONT LET GO UNTIL DONE
feed in new rope , tie knot in rope, replace handle ,tie knot in that end. NOW YOU CAN LET ROPE RETURN IN SLOWLY
May 10, 2014 | Mtd Products Yard Machines 158CC Tiller
Mtd pro bc263rs
If it has rivets holding it . You'll be better off ordering a new pull starter assembly three bolts hold it on simply remove 3 bolts put new one on reboot it on and done . those housings have a tightly wound coil spring. I've yet to see one get put back on tight enough.
Sep 29, 2013 | Mtd Products Yard Machines 158CC Tiller
How do I replace the starter pull cord on a Yard Machine 21 inch rear bag mower
New "powermore" engine? recoil rewind starter comes as a complete assy. If the spring is broken this is your only option
Oct 28, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have an MTD Snow Thrower Model 2M1 with a broken starter rope. I replaced the rope but cannot get it to rewind the rope after I pull it. What am I missing when I reinstall the rope and spool?
When you have the starter top removed, you must wind the spring BEFORE installing the rope. Wind the pulley until it is at maximum tension, then unwind it until the hole in the pulley lines up with the eyelet on the starter top. Now, put the rope thru the eyelet and into the pulley hole. It is helpful to have somebody holding the tension on the pulley, or you can insert a small tool thru the vent holes to hold the pulley in place. Use a figure 8 knot on the rope. Go ahead and tie the handle onto the other end of the rope, and release the pulley tension. It should now recoil into the starter housing. Test pull the rope several times to make sure it is moving freely. Reinstall the starter housing onto the engine and retest.
Dec 01, 2010 | Mtd Products Yard Machines 158CC Tiller
I nee to replace starter rope on tiller...
O really, u have a easy task here. Remove that pull rope coil housing and get it on the bench. Don't take any thing apart from here, that coil spring inside is a whole different religion test. Cut the knot and remove the old rope if it already hasn't broke, but get the old rope in the trash. Mark the rope hole some how in the coil housing against the hole in the housing where the rope comes in from the outside to get a line back through it all. Use braided nylon the same size as the old rope. Twist the coil back up enough to take up all of the new rope and still have some tension, line up your marks and clamp with c-clamp or vise grips to hold your coil tension. Tie your new rope to the handle and thread the other end from the outside through the holes till u see the end of the rope in the knot hole in your coil. grab with some needle nose, pull r up through and tie your knot. Make sure with a tug she's going to hold and release the clamp. Your back in business pal.
Never give in to the repair shop buzzards. ballping
Jul 21, 2010 | Mtd Products Yard Machines 158CC Tiller
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Toro Lawn Mower With Toro Power Tools Logo
584 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
