Question about Belkin F1DK102P 2-port KVM Switch
Belkin 2 port kvm toggling
Can you tell me how to toggle between the 2 pcs?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Re: belkin 2 port kvm toggling
What is the model name?
Press Scroll Lock two times within two seconds. Then press the Arrow keys, up or down to switch between ports. Or press Scroll Lock two times and the press the number One or Two key to switch between ports.
Posted on Nov 16, 2007
0 characters
3 Points
How do I select pc using Inland kvm 2 port switch?
Try this
[Scroll Lock][Scroll Lock]1 to switch to computer 1
[Scroll Lock][Scroll Lock]2 to switch to computer 2
There should also be a toggle button next to the mouse ports on the device itself.
Jul 13, 2014 | Linksys ProConnect 2-port KVM Switch
My iogear KVM switch will not toggle between machines
Try following the this link and see if it helps. It helps to explain how to connect the keyboard to the KVM since the keyboard port is the only port that will recognize the port switching commands.
Jul 17, 2010 | IOGear GCS632U 2-port KVM Switch
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
Feb 15, 2010 | IOGear GCS632U 2-port KVM Switch
Where can I can the drivers for the Belkin 2 port KVM switch F1dk102u
The Belkin 2 port KVM switch doesn't need drivers to work, it is simply a plug and play switch. You plug your keyboard, mouse and monitor into the control box, and your computers into the ends, and off you go. You toggle between computers with the switch button, and if you turn off one of the computers, it automatically swiches to the other one.
Nov 11, 2009 | Belkin F1DK102U 2-port KVM Switch
How to daisy chain iogear 8-port miniview
GCS78 can be daisy chained up to 3 levels only.
Let's say you will start with two levels. KVM1 and KVM2.
The ports 1 to 7 of KVM1 should be available for computers, but the port 8 of your GCS78 is for your KVM2.
The port 1 of your KVM2 should be connected to the port 8 of your KVM1. And the rest of the ports of KVM2 should be avail for the computers as well.
Toggling between computers. You need to quickly hit Scroll Lock twice to enable the OSD of your KVM switch. From there, it will give you an option to select which computer you would like to access.
Or you may manually toggle between computer. Here's how:
Scroll Lock twice + port # - Example: Scroll Lock twice + 5 + Enter - The KVM will switch to the computer that is connected to port 5 of KVM1.
If you would like to switch to the computer that is connected to KVM2:
Scroll Lock 2x + 8 (because KVM2 is connected to port 8) + Enter - now the focus of the toggling is in KVM 2. Now, you may hit again Scroll Lock2x + port # + Enter.
You may also refer to the user manual of your KVM for more info. Look for the OSD portion.
Thank you and good luck!
Oct 29, 2009 | IOGear (GCS78) 8-port KVM Switch
On my KVM switch it works pressing
Scroll lock key twice then
press up or down arrow
to toggle
Apr 11, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
I need the combination to toggle between 2 PC.
Scroll lock + scroll lock
Should fix your problem....
In my case, my logitech keyboards don't have a scroll lock...which kinda makes my life harder...
Mar 25, 2009 | Linksys ProConnect KVM2KIT 2-port KVM...
How to switch between computers
Do you know which model you have? Most KVM's switch by hitting Scroll-Lock twice kinda fast and then the port# you want to switch to. In your case it would be 1 or 2. If that doesn't work let me know what model you have and I will give you a definate solution
Mar 20, 2009 | Belkin F1DL102P 2-port KVM Switch
Problems with 2 Port KVM Switch with Built-In KVM Cables
The monitor is not detecting the video signal from your computer. Assuming both of your computer video cards have been tested and really work I would try the following: Try switching the cable sets that connect the PCs to the switch. If the problem follows the cable set then it?s likely the cause. If not then try switching the cables that plug into the switch so that PC#1 is now connected to the port where PC#2 originally was and vice versa. Again if the problem stays at the same position then I would suspect a defective switchbox. If it doesn?t then you probably have an issue with one of your PCs video cards. I know this is two months late but perhaps but hope this helps you or someone else researching a similar problem.
Apr 23, 2007 | IOGear MiniView GCS62 2-port KVM Switch
Belkin F1DK102P 2-port KVM Switch Logo
214 people viewed this question
Top Belkin KVM Switches Experts
Sudeep Chatterjee
Sudeep Chatterjee
Shahzad  Waseem...
Shahzad Waseem...
Are you a Belkin KVM Switch Expert? Answer questions, earn points and help others
