Question about Dometic Rooftop RV Air Conditioner
A/c turns on for 10 minutes
I have a dometic 595 Series quick coolWhen I first turn it on, it runs great (air from duct is cool and temp in camper starts to drop).After 5-10 minutes fan and compressor turn off.Then the fan turns on but no a/c. Then fan turns off and a/c turns on no fan.Start up capacitors?
  • 3 more comments
  • davenon Jul 15, 2009
    Model is 59516.601 and is 10 years old.
    Thermostat was already replaced but it's model no. is 3107612.008
    Model is 59516.601 and is 11 years old
    Thermostat is 3107612.008. Already replaced that thinking the sensor was bad. It did run longer, but now after 10 minutes, the unit shuts down and the above mentioned occurs.
  • davenon Jul 16, 2009
    Will get back to you after this weekend
    My camp is 1.5 hours away, but go out.
    Thanks for the info.
  • davenon Jul 20, 2009
    OK,
    Back from another crappy weekend where the A/C still was not needed (good and bad thing here).
    This is what I found.
    No Dirt/debris/wasp nest was detected where you suggested to look
    Early this spring I changed the fan motor as it was making loud vibrations last fall (before it broke down).
    After looking at the schematics, I found that I had made a wiring mistake. The Fan and Compressor start capactor wires were reversed (Fan start going to compressor run cap and vice versa).
    After fixing wire error, I turned on the ac and my circuit breaker blew (Not main circuit, only ac circuit). I reset the circuit breaker and it immediately blew again. I reset it 1 more time and the ac turned on.
    The A/C was working and blew cold air for aprox. 15-20 minutes.
    Then at about 75 degrees (temp was 78 when I turned it on), the unit shut down. AFter 5-10 minutes, the fan turned on without a/c and run 5-10 minutes.
    This happened twice without ac.
    Then ac compressor turned on, but no fan.
    At that point a shut unit down as compressor was running without the fan.
    Additionally, when the compressor turned on the 2nd time, it was very laborious trying to start.
    My thought is that the start and/or run capacitor is leaking and not maintaining a full charge.
    So when I tried to turn on ac tripped breaker. cap got a charge and ac worked. Or possibly the compressor freezing sensor?
    Thought or ideas on this theory?
    Thanks for all your help so far by the way.
  • Mike Butler
    Mike Butler May 11, 2010
    Something doesn't make sense, obviously. Can you get complete model # off upper unit. remove filter cover & look up on bottom of upper unit for complete number. Also, thermostat model please. Age of unit?
  • Dometic Master
  • 6,674 Answers
If it was start up capacitors, it wouldn't start initially every time. Do me/you, a favor, and remove your filter inside (return air) , and if it's a ducted system, remove entire plastic cover inside. Take a flashlight & look way up where filter covers in hole & take a good look at cooling fins on evaporator (front of AC). Look for restrictions such as dust etc. That dust will turn just like mud on there due to condensation mixing with dust, and block off flow which could cause unit to freeze up & compressor to kick out. If your real ambitious, and find lots of dust there, taking cover off roof unit would be next, and check same there at back end (condenser) coils & cooling fins.Get back to me after inspection from inside. Could still be electrical but lets check that it has proper maintenance & best chance to work properly by doing this first.
Posted on Jul 16, 2009
  • Mike Butler
    Mike Butler Jul 16, 2009
    Forgot to mention, wasps like to make nests under those covers, so a little investigating ( bang on cover, & pay close attention, if you don't see them going in & out when you, or whoever gets up there.) may save a good sting. When/if, you do go up & hit the cover, make sure your between the AC & ladder down. I made the mistake of hitting it one time & heading in opposite direction away from ladder. Pretty big swarm came out, but luckily I got far enough away, until they settled down, then made it to the ladder came back next morning, with spray. Sundown or cloudy day good time to pull cover off. If you do it early in morning just be careful as roof is usually wet & real slippery. Good Luck
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
Own 2005 27.5' Wildwood Trailer with a Dometic a/c ducted unit. Last few times out it freezes up initially first few times (pocked circuit breaker once then I turned it off after few minutes second time)....
Don't block off any ceiling ducts and see what happens. If you've closed off any forced air ducts, the unit will freeze up, if too many are closed off. Also, if you shut unit off (compressor) give it 5 or 10 minutes before you turn it back on.
May 21, 2010 | Dometic Rooftop RV Air Conditioner
My dometic 15k brisk-air cont. cycles on-off
Actually, the dealer is somewhat correct. In the hotter months of the summer, the rooftop units have a tendency to freeze up if not run on high cool due to the lack of air movement across the evaporator. If the unit fines on High/Cool, then run it in that mode but adjust the thermostat.
It should not however, cycle on and off that fast unless you have a bad freeze switch or the incoming AC is too low. If during that 8-10 seconds, the air begins to get cold and then it shuts off, then I would say you have a bad freeze switch. If it runs fine on high, but shuts off in low, I would say it is a lack of air movement.
Hope this helps,
Jeff
Rate me please!!
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
RV AC/HP Rooftop 15,000 btu Penguin
Is there by any chance a cool air duct or register, or maybe return air duct near the thermostat, or perhaps on opposite wall,(behind it) that may be throwing it off? Have you tried just draping a small towel or facecloth over it to see if that changes anything? I've had one that acted similar in a 12 wide, and it turned out to be that the return air was directly behind it, and caused cool air to rush in around hole for wiring of thermostat, causing it to kick in & out about every 5 minutes. Heard a whistle when I was checking thermostat, and a light went on in my head. Plugged the hole up good & all was well. have you tried this number & link to contact tech assitance at dometic for some advice on it? Phone 1-800-544-4881 and ask for technical assistance. CustomerSupportCenter@DometicUSA.com <CustomerSupportCenter@DometicUSA.com>
Aug 14, 2008 | Dometic Rooftop RV Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Brisk air, dometic rv a/c unit
possible tired motor, or dying capasitor
Jun 24, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
566 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
