Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi aqua pulse 6965 AL5 error
Hi trying to fix my sisters dishwasher because the al5 error message keeps popping up i have followed all the solution i can find and still cannot fix this i have tried:
emptying the pink pipe
turning water pressure up and down
and checking for any blockages but still get this error apart from this the machine is in very good nick and want to try anything before scrapping it as she has 3 small children and desperatly needs it so any solution would be great.
fingers crossed cheers vic
  • 3 Answers
It may be the WMS is blocked, i get AL5 or AL6 at the start of the program. here is how i have fixed it the last couple of times. WMS is around £70 (in 2010) - i have that on mine every 4yrs or son - i change the WMS sometimes called the water management system or water softener. it located on the left of the machine.
the floor will get wet during this repair.
you need to turn off the power; turn off the water supply; to it take the top off remove the two screws at the back of the lid. then work your way around the left hand side removing the panel retaining screws. once that is off you can see a large blue plastic 'thing' this is the WMS that you need to replace.
to remove this you need to remove the screws around the inlet for the water, i think there are 5 or 6, some are revealed once cover plates are removed.
there are 5 or 6 retaining the WMS; the most important are the tow at the bottom toward the middle.
now gently prise off the WMS releasing the tabs and catches. do not pull it off as there are some connections still to be disconnected. As to lift the WSM at the bottom right, behind the WMS there are three pipes held on with spring clips, these need to be released. then the WMS should lift off.. replacing is the reverse of the above.
Posted on Sep 09, 2010
Aeg slimline dishwasher 64800. AL5 alarm, but fills up
This control procedure is in operation only during the cold wash and heating phases.
  • Once the pressure switch has closed in the "full" position, it must remain "full" until the subsequent drain phase; if the pressure switch signals "empty", the fill solenoid is activated for a period equivalent to the period of aperture of the pressure switch.
  • The maximum aperture time for the pressure switch (T) during the entire phase is 60 seconds; if this period is exceeded, an alarm condition is generated.
Alarm: AL5
Possible causes:
  1. Dishes upside down
  2. Central filter clogged
  3. Siphon effect created in drain hose
  4. Leakage in sump - pressure switch tube.
Dado
Mar 02, 2014 | AEG 18 in. Favorit 64800 Free-standing...
Zanussi problems
could be the water valve on washer is faulty, not opening,
sometimes forgotten, is the water tap is not turned on.
Check that the Inlet Hoses are connected properly.
Nov 18, 2013 | Washing Machines
Aqua pulse mains light ok but does not run ?
You probably have either a bad powercord, motor or control panel.
May 11, 2012 | Zanussi Dishwashers
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
Hi could you tell me what AL6 means on my dishwasher and how to fix the problem, thanks
it may be the WMS is blocked, i get AL5 or AL6 at the start of the program. here is how i have fixed it the last couple of times. WMS is around £70 (in 2010) - i have that on mine every 4yrs or son - i change the WMS sometimes called the water management system or water softener. it located on the left of the machine. the floor will get wet during this repair.
you need to turn off the power; turn off the water supply; to it take the top off remove the two screws at the back of the lid. then work your way around the left hand side removing the panel retaining screws. once that is off you can see a large blue plastic 'thing' this is the WMS that you need to replace. to remove this you need to remove the screws around the inlet for the water, i think there are 5 or 6, some are revealed once cover plates are removed. there are 5 or 6 retaining the WMS; the most important are the tow at the bottom toward the middle. now gently prise off the WMS releasing the tabs and catches. do not pull it off as there are some connections still to be disconnected. As to lift the WSM at the bottom right, behind the WMS there are three pipes held on with spring clips, these need to be released. then the WMS should lift off.. replacing is the reverse of the above. i did not find it too difficult other than the last bit with the pipes but you know your abilities. Good Luck
Jun 08, 2010 | Zanussi 24 in. DE6965 Built-in Dishwasher
The Zanussi Aquapulse (de 6965) Fault Code AL3.
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Zanussi aqua pulse de 6965
We have AL5 quite requlary. It seems to be related to the pressure of the water going into the machine. I think if it is too high this alarm can be tripped.
There are two main ways we rectify the problem:
1. switch off the inlet water supply. Disconnect the hose at the machine. Let any surplus water drain out (only a couple of spoonfuls). Reconnect and switch on water.
That sometimes resets a sensor inside that relates to the AL5.
2. If the above fails then we remove the panel where the inlet water hose connects to the machine (There are three screws). Then carefully left this panel away from the machine. It will not come right out as it is connected to various bits inside the machine but you can get some access inside. On the left hand side there is a pink pipe with a white stopper on the end. Remove the stopper and let an excess of water out (this might be as much as a cup full). Of course, this must be done with the machine switched off and un-plugged from the mains!! There are electrics inside.
Once the pink pipe is drained, put the stopper back on and reassemble and connect. 90% of the time this works fine.... but the problem does come back.
If it doesn't work after the second procedure has been done then try leaving it over night (with the water inlet switched off) and try again in the morning.
I have experimented with putting the inlet tap half on (i.e. to lessen the flow of water) and that seems to give us longer before the problem returns.
I checked on a site a while back which had suggested that Zanussi were aware of a design problem. Of course, unless cars, they have no recall policy. I have tried to ring them once or twice but have got nowhere. Its hard to tell at times whether you are ringing the right company let alone the right department!!
Aug 24, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Jun 04, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
530 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
