Question about ASUS Eee 4G Notebook
I have a eee asus laptop. I cannot startup the window at all. The pc show this message; "Windows could not start because the following file is missing or corrupt C:windowssystem32configsystem " how can i repair this file. I cannot reinstall because ASUS EEE come with preinstalled window. How do solve this problem ?really appreciate your help. Thanks
  • konsang2323 Jul 13, 2009
    asus eee don't have any cd-rom drive. how can i recover from the cd?
    The ASUS EEE come with the preinstalled windows. If i reinstalled the window from CD , will it causes problem ?
    President:
  • 1,383 Answers
You have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
Posted on Jul 13, 2009
  • kishor
    kishor Jul 14, 2009
    no it dont create any problem if you install from disk.
  • kishor
    kishor Jul 14, 2009
  • ASUS Master
  • 19,396 Answers
If the computer does not start, not even in Safe Mode, the problem can be fixed only reinstalling Windows.
On Netbooks with no optical drive, like your EEE, the easiest way to reinstall windows is using an external CD rom connected to USB and a Windows install disk.
An external CD rom starts at about $24: Amazon.com: 24x USB External Slim CD-ROM
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
On screen message telling me windows could not start because the following file is missing or corrupt- <windows root>\system32\hal.dll. Laptop does not start or boot properly
Time to get out that restore disc you made when you first got your laptop. The boot sector has errors. Boot with your rescue disc and run CHKDSK/F to clear the errors.
Hope that helps.
Feb 16, 2011 | ASUS Eee PC 701SD 8G Notebook
I have a Asus eee 1005HA running Windows XP. When I try to boot, I get an error message saying "file missing or corrupt \windows\system32\config\system You can attempt to repair this file by starting the...
Ring this number: 0870-120-8340. You might be able to get a disk of them at Asus,if not im sure they will help you with the best possible advice---Good Luck!
Davey Snake!
Oct 25, 2010 | ASUS Eee PC 1000HE Netbook
I dont know how to reboot my ASUS eee LapTop
Hi there, If you want to 'reboot' or re-install windows, then you will need to locate your windows CD, insert this into your Eee PC then re-start, then follow the prompts on screen to re-install windows.
Cheers.
Jul 09, 2010 | ASUS Eee PC 1000H Laptop
I get the message Windows could not start because the following file is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM it tells me to use the set up CD=ROM I attached an external drive and inserted the...
Enter your Windows OS installation CD into your ASUS laptop's CD-ROM, then restart your computer.
When your computer restarts, instead of booting up normally you will now see a Windows "Welcome" screen. Press "Enter" to continue. At the next screen, press "F8" to accept the Windows licensing agreement.
From here, i believe you can continue the process to reload or repair the operating system on your system.
Take care.
Jul 01, 2010 | ASUS Eee 4G Notebook
Error message
Can you get as far as the F8 boot menu? (press F8 to bring up a menu after booting). Try it and see if you can boot to last known good configuration or in safe - mode.
If that doesn't work, and if you have your original Windows CD, insert that and follow the instructions to repair your installation.
If none of the above works, let me know and I'll try to help you further. If it does, please rate. Thanks.
Apr 19, 2010 | ASUS Eee PC 1000H Laptop
Asus eee pc 900 /windows/system32/config/system
2 problems, your using a netbook that doesnt have an optical drive (cd/dvd) and you need a windows cd.
I dont think there is anything you can do until you call your retailer and request a copy of windows cd.
After that you can do a windows repair. Use the link below to see you options for accessing the cd once you have it.
http://www.itworld.com/windows/68069/three-ways-install-windows-7-netbook
Aug 29, 2009 | ASUS Eee PC 900 16G Notebook
I HAVE NEW ASUS 1005HA ON STARTUP IS SAYS WINDOES COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT: wINDOWSSYSTEM32CONFIGSYSTEM. IT THEN ADVISES YOU CAN ATTEMPT TO REPAIR THSI FILE BY...
This shouldn't be your problem; if the unit is new, go back to the source from which it came and let them deal with it. Any new machine should start without that kind of problem. Since it is missing a critical file, you may not be able to start it in the so-called 'Safe mode.'
Jul 16, 2009 | ASUS Eee PC 2G Surf Notebook
Desktop theme changes at startup
That's not supposed to be a problem... When you log in to your account windows loads your personal settings, as well as other programs, so it's supposed to take time. Windows probably has the theme set on default so it would show that while your settings are loading. That or you've got a virus... But... if you think your computer is unusually slow then that's a different problem. Try cleaning up your hard disk space and doing other sorts of stuff, like scanning for viruses to make it run faster.
Jan 18, 2009 | ASUS Eee PC 1000H Laptop
ASUS Eee 4G Notebook Logo
774 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
