Question about GPX S7694 CD Shelf System
Light is on but nothing will play.Light won't turn off when on/off switch is used.
    Genius:
  • GPX Master
  • 1,550 Answers
Audio amplifier IC damaged
Posted on Jul 13, 2009
When I try to start my spyder sts-se5 I turn the switch and nothing happening, its as if their is no power, no light or nothing. Can you help?
Hi, Sarah and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
Spyder won start Can Am Spyder Forums The factor Community
Thread Won Start won turn over
2014 CanAm Spyder RT Series Repair Maintenance Parts Master Collection...
Can Am OEM Parts
http://www.spyderlovers.com/RT/NEW2010RT.pdf
Sep 15, 2013 | CanAm Motorcycles
Park lights won't turn on.
Turn light on,get a meter,go to bulb and see what it reads,if nothing,then bad switch,
Sep 08, 2012 | 1998 Volkswagen Cabrio
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
CD player won't play
The CD player is defective and should be reolaced, but first open tray and carefully clean the laser lens gently with a Q-Tip and rubbing alcohol and allow several minutes to dry before testing.
Mar 10, 2012 | Compaq Presario CQ50-215NR Notebook
2009 HHR won't start. Battery is good.
Is the security light on or blinking?If not then do you have power to the starter.You can check this with a test light.You should have power when you turn the key to start.The test light should light up.Should be the small wire.I believe it is purple in color.If the security light is on then you will have to get the codes to see what is causing the no start.Hope this helps.Good luck.
Dec 07, 2011 | 2009 Chevrolet HHR
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Won't start. Turn the ignition and nothing. The engine light comes on and the auto theft light comes on for a few moments and goes off. I tried the couple things suggested in the owners' manual...
if nothing happens when you turn the key the problem is most likely the ignition switch and housing(had mine replaced 3 times already. firstr time at 12,000 miles) what you can try is hit key with rubber mallet while trying to turn but this would only be to get it started so you can drive to a chevy dealer(dont waste your time at any old repair shop for this). Hope this helps.
Aug 11, 2011 | 2008 Chevrolet Cobalt
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
Xbox 360 won't turn on!! I was playing my xbox for all of 30 minutes, turned it off, went to turn it back on again an hour later, and nothing!! No red ring of death, no pop or spark, just nothing....
try this
I know its a little annoying but its useful trust me. The orange light usually means a problem with the power supply. This means WORST CARE SCENARIO you have to replace the power brick but you 99% dont have to get a new xbox.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/power.aspx
cheers!
May 15, 2011 | Microsoft Xbox 360 Console
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
GPX S7694 CD Shelf System Logo
126 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
