Question about Whirlpool AWG320 Front Load Washer / Dryer
Doesnt always rinse.
My washer dryer doesnt rinse the water all the time. About 30 % of the time, it works correctly.
  • whirlpool181 Nov 21, 2007
    Thankyou for your prompt reply. Will this fix also be the same for model AWG329.
    Also where is the best place to order this part from ? how do i find out the part number ?
    Novelist:
    Champion:
  • 244 Answers
Now the problem with this is a faulty solenoid situated at the back under the lid were the pipes attach should be the 1 with more exit pipes coming from it change this and should work fine m8
Posted on Nov 17, 2007
Whirlpool washer finishes but sometimes doesnt drain/ rinse. It finishes sometimes with the dirty water in it and sometimes with the rinse water in it. Yet sometimes it finsishes everything correctly...
Hi give this a go. Do a hot wash with some calgon or other washer cleaner no clothes just the cleaner I would put more than is normally recommended in try that a couple of times. I think your pipework and level switches are clogging up with crud.
Hope this helps
Steve
Jan 05, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
Candy as108
IT has shorted out u will need to replace board
Aug 21, 2013 | Washing Machines
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag Neptune stops during rinse cycles
from what you say it doesnt sound like a water valve. does it fill to correct level the first time round?
Mar 27, 2007 | Maytag Neptune MAH7500WH Front Load Washer
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Washing Machines Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
