Question about GE JE1590 Convection / Microwave Oven
Runs when door is closed, only way to stop it is to unplug the unit.
Close the door and the unit starts running. All front panel buttons work (including the clear button) but will not stop the unit from running. Let it run a few seconds or so and touch the glass plate inside and plate is warm/hot, so heating is taking place. Could this be caused by faulty door switch? plus how to remove cover due to two lower torque screws that seem to require a special tool with a hollow center in the tip.
  • GE Master
  • 9,098 Answers
It's likely a bad switch or switch mount.
Some models use an tamper-resistant screw which can be removed with a specially-designed tool available from home improvement stores & appliance parts stores.
But some folks just use a hammer to tap and loosen the screw, then a "star", t-type, or small flathead screwdriver can be used to remove the screw. (see photo)
Sometimes the screws are tough, so you may only be able to just bend the post slightly with a punch, then a small flat blade will "grab" enough to turn the screw. Pliers on the handle will help, too.
Another creative solution is to use a hacksaw or a Dremel tool to carefully cut a slot in the head so a flatblade will fit it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
  • 473 Answers
Sounds like it has a faulty door switch. These are call safety torx. You can purchase them at most stores that sell tools, like Sears, Lowe's, Home Depot for example.
Posted on Nov 16, 2007
Microwave wont shut off
there is just a malfuction in the circute board go and get it fixed
Apr 01, 2015 | Danby Microwave Ovens
Unit starts automatically when door is closed
please review this and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Nov 18, 2013 | GE PSA2200RBB Microwave Oven
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
In order to start the microwave i have to push the door
The door switch is loose or fualty you can adjust the switches first to see if it hase just moved if this does not work then replace it.unplug the unit and remove the cover panel look between the controll panel and the cavity on the back of the front panell you will see two or three switches the (GREY or BLACK ) look for the retaining screw loosen slightly and adjust if this does not work the take notes of the wire positions etc on the switch get a new on eand replace close unit plug and play
Dec 29, 2009 | Whirlpool GT4175SPS Stainless Steel 1200...
Model JVM1443 fan runs all the time when unit is
The top door switch (door sensing switch) is defective, or its mount is loose or broken.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
GE microwave Model JVM1650SH01 innternal fan runs continuously
Check the door switches-I think you will find one or more either bad or not being contacted with the door latch.
Jun 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
JMV8208AAS Jenn-Air runs all by itself
check the door connection. it may be stiking. unplug from the wall and open up, spray wd40 and give it a clean.
Dec 13, 2007 | Jenn-Air JMV8208A Microwave Oven
GE JE1590 Convection / Microwave Oven Logo
67 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
