Question about Sony Dvcam DSR-PD150 DV Digital Camcorder
On my pd150 camcorder, the self-diagnosis display shows C:31:23. I have tried all suggestions in the owners manual, but nothing works.
  • kyledameron Jul 13, 2009
    I tried smacking it - on bottom and side opposite tape - no help. The code did change temporarily from C:31:23 to C:31:22 then back to C:31:23. I tried loading a brand-new dv tape and now it will not eject!
    I appreciate your suggestions. I will ship the camcorder for repair but feel we did everything we could to fix it ourselves prior to shipping.
  • Sony Master
  • 2,200 Answers
The 31 in this code relates to an electrical component issue often resolved by following the advice in the manual i.e remove battery from unit for 60 seconds and then power up again.
The 23 in the code relates to internal gearing - if it is worn or sticking it in turn activates the 31 fail safe - so you can see that in fact this error relates to two issues occuring in the camera - one electrical and one mechanical.
The Solution- To be Performed At Your Own Risk!
If following the user manual recommendations has failed to resolve the issue for you - error 23 can often be resolved by ............... smacking the side of the camera relatively hard with the palm of your hand !!
Don't believe me? See http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/Sony_DCR-TRV18_-_Error_Code..html
This is a fairly common issue with these cameras and the smack is often enough to release the gear mechanism and resolve the problem. The only alternative is to return the camera for a service repair.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 13, 2009
  • Radio Code Pro
    Radio Code Pro Jul 13, 2009
    It appears the gear mechanism is the problem and this has further jammed the mechanism. As you see from the link many people have had success with it but its looking like the mechanism in your case is so far gone it will require service attention.
  • Radio Code Pro
    As regards your current tape stuck problem:
    TRY THIS: Power off your camcorder and remove the battery. With the battery removed, move the power switch to ON. LEAVING THE POWER ON replace the battery. You may find the tape will eject.
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
How many mega pixels for video is the sony pd150 camcorder
That is a standard definition camera. Its like 1/3 of a megapixel
Hint multiply 720 x 480
Sep 29, 2013 | Sony Dvcam DSR-PD150 DV Digital Camcorder
M using sony pd150, 1st problem = menu button is not working 2nd problem = sometimes viewfinder geting off 3rd problem = video in viewfinder 180 degree rotate please help me
Wow you simply have got a few snags, this camera needs a reset, press reset button, yes I know you will lose time/date but at least it will sort things.
David
Jun 24, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Sony DSR-PD150, Yellow screen and won't record, help!¬
flex wire connecting LCD with camcorder might be a problem it's very common.I did in mine .
Good luck
Aug 18, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Timecode break after a camera cut. PD150 & PD170
dear,
this problem is related to the head drum of the camcorder as the head drum gets dirty ,this problem does occurs but using cleaning tape wouldnt help much, asu need to clean the drum assy manually.
Mar 24, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
C31:22
Your camcorder has a self-diagnosis display
function.
This function displays the current condition of
your camcorder as a 5-digit code (a combination of
a letter and figures) on the screen. If a 5-digit code
is displayed, check the following code chart. The
last two digits (indicated by ss) will differ
depending on the state of your camcorder.
Look up the error code in you manual
Sep 12, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Color distortion
Sounds like the same problem that I have, I think it might be the Color CCD chips!
Jan 22, 2008 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Sony Dvcam DSR-PD150 DV Digital Camcorder Logo
82 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
