Question about Lexmark X3650 Printer
When trying to scan it says to plug in usb flash drive but the usb lead is in I have been printing from it all day?
  • 55 Answers
The usb cable is sub-standard, get a new 2.0 usb and i can assure you its going to work, make sure you buy the original 2.0 usb cable. thanks
Posted on Jul 13, 2009
What to do when your alienware m14x does not read USB flash drives?
good day have you been tried to plug the usb flash drive with other usb input of your pc or tried to plug with other pc just to ensure where the problem. if still doesn't read using with other pc that was mean your usb drive might have problem. if the case that your usb drive work with other pc the problem is with in usb jack which need to check weather loose wiring or software problem.
May 18, 2014 | Computers & Internet
Cannot print from flash drive
One method, press the SCAN button (LCD will show Save to PC) then insert USB flash drive into the Direct Print Port. Use the left and right arrow button to select USB flash drive, then press OK button.
Second method, is press the FAX button then press the Menu button. Insert the USB flash drive into the Direct Print Port.
If you can access the USB drive using either method then you know the printer recognized the drive successfully.
Nov 05, 2013 | Canon pixma mx310 color ink-jet - fax /...
My toshiba 16 gb is not reconized
if you are referring to usb drives or scan disk cards if its a scan disk card it must have device to plug it into (camera ,phone,navigator) if its a usb drive you must plug it into a usb port if you want to use the usb drive
click start click on my computer you should see your drive it will be listed as something like G: or H: or if its in a device it might be seen as a mass storage device
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question/exclamation mark ? ! or a red X you will need to update the driver
right click to reinstall drivers
if you can see your usb drive but its not working
if your computer came with a motherboard disk the drivers could be on it
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Mar 05, 2012 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
How to scan virus from Flash Transcend
This the best idea that I have.
Download Kaspersky antivirus guard and install and activate the virus guard and you have to update the anti virus too.
Then plug the Transcend 4 GB jetflash and when plug this anti virus ask you what do the select option Full scan and the If the Flash driver has virus it will neutralized the virus.
Thank you.
Sep 12, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a Dell P703 and want to scan photos to a flash drive but the printer will not, it keeps asking for a memory card when I insert a memory care I receive the message "Please insert memory...
I'm not so sure that this printer supports scanning photos to a flash drive. If you take a look at the user guide, the only advice given about scanning problems is that they want you to make sure the printer is attached to your computer properly.
This leads me to believe that what you are trying to do is not supported. The USB por that is available is most likely used to plug in a camera directly so that pictures can be copied from it and printed.
http://support.dell.com/support/edocs/systems/P703w/en/UG/troubles.htm#wp1180022
Jun 13, 2011 | Dell P703w Printer
My Brother MFC-5890CN Printer wont print.It does scan.I have tried re-installing the drives but when it gets to the last section the box just asks for the machine to be connected. I have also changed the...
I can't print nothing from my PC or trough network, but still I can Scan, Fax, etc. I'm using Windows 7 Home Basic, I already installed the driver ( "Connection via USB Cable" ) and I have plenty enough ink ... I checked the Settings, Test Page is OK, but nothing else want to be pinted. I had a problem with my MFC 5890 in the very begining ( nearly 2 weeks ago ) so I had to unplug and than plug in the USB Cable and in this situation the printing of my "pending documents" was successful, but from few days ago there is no such a thing that could make it print. Please help
Dec 31, 2010 | Brother MFC-5890CN All-In-One InkJet...
USB Antivirus
Vhinz_dprinz, To answer your question if you're using a USB flash drive, I would assume that you have a PC that you're using as well. Your PC should have an antivirus installed on it, if so you can open up the control panel of your antivirus program and set it to scan it. I'm sure you're well aware that once you plug the flash drive in, it pops up as a removable drive, you can then tell your antivirus program to scan that particular drive.
Now another thing that you can try is installing AVG antivirus, it's a free download for personal use, you can set the program to auto-scan your harddrive and any other removable drives attached to it. Normally you should set it to scan at night while you're sleeping and not using the flash drive. Let me know if you need further input on this issue. Goodluck
Jan 22, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Printer does not print scanned or software generated images.
The ink tube that runs from the rear of the cartridge slot to the print head was clogged. The tube was removed and cleaned with compressed air.
Jan 08, 2009 | HP Photosmart 3210 Printer
Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
Feb 13, 2008 | Cameras
Lexmark X3650 Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
