Question about LG WM-2277HW Front Load Washer
Getting OE code but nothing is clogged . What do i need to do ? Is it the pump motor?
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 13, 2009
I am getting an OE code on my dishwasher
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | LG LDF6810ST Stainless Steel Built-in...
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
Getting an OE error code on WM2016CW washer. Have checked the hose for bends and emptied the drain filter? Still getting error message?
OE error is because the machine is slow to empty..Check and see if the machine is draining slowly or not at all..Sometimes coins get caught in the impeller itself...The type of pumps used on LG machines can fail because of muck and detritus getting behind the impeller back plate..Dismantle pump. Mark pump and body to help with re-assembly. If impeller comes out of motor body, you'll have to feplace the pump motor..Universal pump motors are generally ok.. Gravity drain to empty machine.. Good luck....Nomess
May 19, 2010 | Washing Machines
I am getting an OE code on the display. I changed
Make sure you check to see if anything is caught inside the drain line, or the bottom bellow (black hose that connects from the tub to the drain pump/motor.)
Mar 25, 2010 | LG WM2487H Front Load Washer
Getting the OE error message on LG Tromm
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
LG LDF6810ST dishwasher
Steps to fix OE are as follows:
-Check the Drain Hose is not kinked or blocked.
-Are all wiring connections OK?
-The drain outlet of sump is blocked.
-The Drain Pump/Motor or circuit has failed.
To check the pump motor: -Measure the electric resistance of Drain Motor. (best between 20-40 ohms) If out of range, replace the Drain Motor or repair the Circuit.
Good Luck! Please report back your findings.
Feb 14, 2009 | LG LDF6810ST Stainless Steel Built-in...
Error code oe
That's not OE, that's DE = Drain Error. Open the access door at the lower left on front of the machine. Use the small hose to drain the remaining water out of the machine, then open the large knob which is attached to the filter. If there is nothing in the filter, you may have an object which made it past the filter and is blocking the pump impeller, or the impeller may have come off the pump motor shaft, which would require pump motor replacement.
Oct 15, 2008 | LG WM-1485FHD Front Load Washer
LG WM-2277HW Front Load Washer Logo
196 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
