First thing first chang the plugs that model you have is bad about fauling plugs do to not allowing motor to warm up even if you were moving it five feet from were it was setting and don't matter if you just replace them early in the year, if it is cold this will happen with out ? So do this first.if that don't fix the problem Ok on your intake tube between the air box and the throttle body should be a small sensor mass air it has a small screw that holds the adjustment for it loosen the screw and and turn it counter clock wise just slightly tighten back and start bump throttle keep repeating the process untell you have a quick throttle response . Be sure to shut off and restart each time you move it keep your eye on the check engine light when you have it right the lite will stay out .good luck
