SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
SOURCE: I have a Honda GX340
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
SOURCE: gx340 honda engine starts first
Adjust your needle valve. Default value is normally one and one/half turn open from closed. Do not jam either way ... it is delicate and subject to damage. When you get it started, you may have to adjust it a little more one way or the other (open or closed).
Thanks for your question @ FixYa.com
