My US Logic monitor doesn't show any image, only the power light blinks every second.
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to trythe repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 14, 2009
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
BuddyMc
Feb 22, 2012 | Samsung SyncMaster 940N Flat panel Monitor
Hi, My g. door opener doesn't work. The
5 Blinks on the logic board LED indicates that possibly the motor has overheated. If you have unplugged the unit and waited minimum of 30minutes before plugging it back in, and it still will not operate, then the logic board will need to be replaced.
I hope this helps
May 12, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a star logic monitor and it is not working. When i insert the power cord a dim blue light blinks, but then when i insert the computer to monitor cable, the dim blue blinking light goes away and it...
  1. Please try by reseating the RAM modules.
  2. Please check the VGA output port is properly fixed.
  3. Reset the BIOS to its default.
  4. Check whether the monitor colour resolution is out of range
If yes, set it to default.
Please check whether is works with different computer
IF yes, Check the VGA port.
Feb 07, 2011 | Star Logic Monitor
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
Power light is always blinking and no image on monitor. can you hep me . thanks
this indicates that there is no signal from the CPU to your monitor. the problem may be with ur CPU and not the monitor. There could be problem with your RAM.
Aug 04, 2009 | Star Logic Computers & Internet
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Front panel lights blink on/off once per second
Hey,
I would like to agree to the diagnosis that you have done on the monitor . Thanks for a well complied solution. You can try the following website
http://werepairmonitors.com/monitor-repair.htm
dell generally sources the monitors from NEC,Hitachi or LG.
Thanks
proton
Mar 23, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Monitor goes black but the green light stays on. I turn the power button off and then back on and it comes back on. It may stay on for a few seconds to several minutes.
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on green, but the back lights are what helps support an image from the Front Panel Display.
The only way to fix this is to open it up.
If its got 3 boards inside((logic-->video, Inverter, Power)) The problem is the Inverter. Replace it.
The inverter is the board that supplies power for the backlights to turn on. The backlights
provide a light.for the LCD Panel(provides color and is the logic. ... similar to a projector.
If its got 2 boards inside ((Logic-->video, Power)) The problem is the power supply. The inverter is embedded onto it.
Simply replace the part with a known good one, and you got a spanking new monitor.
Sep 18, 2008 | Computers & Internet
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
