Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
Hello, We have had our Hayward Super Pump 1hp for 6 years with no problems. Just yesterday it started tripping the circuit breaker. It would run between 30seconds to a minute and trip the breaker. Could the pump need replacing already? Could it be the capacitor? Thanks, Kathy
  • 110 Answers
6 years is a good time - you must have house for your pump :)
If you are close to a pool shop - take it in and get it tested - somtimes it will just need a service.
Posted on Jul 13, 2009
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
What else could cause power to pool pump to shut off?
Check the timer clock, the timer maybe faulty or the time is incorrect.
Oct 13, 2012 | Hayward 1HP Super Pump II Inground Pool...
My Hayward 1 hp super pump will run for a second and then trip the gfci. What has happened? Thanks.
Normally the GFCI is doing its job.
Water is getting into the internal of the motor.
Try replacing your Shaft Seal
Jul 31, 2012 | Hayward 1HP Super Pump II Inground Pool...
My hayward 1hp super pump hums when i turn it on but doesn't turn or pump it eventually trips the circuit breaker inside
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Jun 08, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Hayward 1HP for in-ground pool: When I shut the pump off sometimes DE backflows from the filter through the pump and into the pool and accumulates on the bottom. The pump is about 10 years old and it just...
Usually caused by a small air leak somewhere on the pressure side of the system. A check valve on the line coming out of the pump going to the filter will solve problem.
May 05, 2010 | Hayward 1HP Super Pump II Inground Pool...
WE have a EC50 system w/1HP matrix. Pump runs
Hayward Matrixs' have a one year warranty.
If it is tripping the circuit that is usually an electrical problem, and has nothing to do with the motor. Open up that back with the motor off and try to turn that shaft with a flat head, if it turns than it is an electrical problem; if it doesn't then contact Hayward directly for warranty information. Hayward is a pain to get ahold of but they are great about honoring their warranties.
The Matrixs' are fairly new and I have yet to see a shaft freeze up.
Jul 17, 2009 | Hayward EC50C Perflex Filter w/ 1 HP Pump...
My new Hayward Super Pump is over Amping
Sounds like the wire gauge (thickness) is to small
Jun 04, 2009 | Hayward Pool Products Hayward Super Pump
Lossing Prime
It's pulling in air very slowly from somewhere:
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
check gaskets/o-rings-- replace defective ones, lubricate
tighten everything possible
Apr 10, 2009 | Hayward 1HP Super Pump II Inground Pool...
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
611 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
