Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water is accumulating inside the bottom of the freezer.
I have shut off the supply line to the ice/water system, yet water continues to accumulate at the bottom of the freezer (approx. 8 oz. per day. This is a Fridgidaire side by side that we picked up used and it didn't do this at first. It started this after about a month.
  • mkc56 Jul 18, 2009
    model # is FRS26H5SB5. Where does this water go once it is unplugged? I don't have a floor drain basin etc.
Water is accumulating inside the bottom of the freezer and ends up on the floor. The model number is FRS26ZNHW3
Posted on Jul 18, 2009
    President:
  • 1,136 Answers
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 13, 2009
  • Victor
    Victor Jul 18, 2009
    The water will drain into the drain pan below the refrigerator on the outside and wil evaporate into the air.
  • Victor
    Victor Jul 18, 2009
    Hi, If you remove the rear acces cover on the outside in the back, you will see the drain pan around the compressor. Most newer models have the drain pan molded into the frame. You might be able to see the drain tube coming from the freezer side.
    Vic
Water is leaking from bottom of frig, supply line is fine. Its seems to be comming from the front end of frig
Check the drains. It may have been clogged by particles from the food accumulated over time. It may also be from the ice that may have accumulated inside, at the panel at the back.
Jun 09, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag MZD2766GES Side by Side...
Water dripping from inside of freezer compartment.
The condensate drain has a blockage further down and possibly in one of the turns as it leads down to the pan below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie2.gif that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
- Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 24, 2009 | Jenn-Air JCD2389G Side by Side...
We have a side by side Maytag refrigerator. Model # MSD2758DRQ Serial # 14043813YU. The bottom of the freezer is accumulation water and freezing. We turned the ice maker off, and it continued to accumulate...
your drain in the freezer is plugged or frozen ...remove the back panel and pour HOT water down the drain until it runs thru.... hope it helps
Sep 20, 2009 | Refrigerators
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Water is freezing in the supply line for the ice maker
This usually means you have a weeping water valve. The water valve doesn't completely shut down after filling the icemaker. This deposits a staedy flow of water which freezes and accumulates in the tube, eventually blocking it off. You would need to replace the water valve which is located at the rear of the refrigerstor. One othe thing to check would be the water supply to the refrig. If the water dispenser is working fine then that isn't an issue. However, if that is flowing slowly you would need to replace the saddle valve which is tapping into your house water supply.
Apr 09, 2009 | Kenmore 53502 / 53504 Side by Side...
Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Nov 25, 2008 | Frigidaire Refrigerators
Water/freezing to ice at the bottom of the freezer MZD2766ge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all that ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youll melt everything) or by pouring hot water down the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 17, 2008 | Maytag MZD2766GES Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
545 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
